ChinookDriverJoe
Ok, I’ve been searching the site for a while now. I’ve installed the ARB twin compressor in the bed and am working on the wiring now.
The wiring kit that comes with the Up/Down Air mounting plate is designed to have you run the main power loom and switch loom along the frame rail and into the engine bay. They have you power the signal wire (purple) from an up-fitter wire.
Problem is all my up-fitters are used up. So I brought the switch loom into the cab through a grommet in the passenger floor. I installed the switch in the center console tray. Now I’m trying to find appropriate switched 12v power in the console.
I suppose the idea is to have the compressor turn off if the engine isn’t running but accessory power would probably be fine.
Can I tap the 12v power port (cig) or USB ports for this signal power? Do they turn off via timer or when the door is opened and key off? Any ideas?
