Pocket light sides different?
Irregular F150
its terrain good sir!
Got these all installed and went to adjust them. The drivers side leds set out and in, so getting them facing front isn’t working and they hit the bumper. The passenger side seems to be fitting great. Brackets are baja and the leds are diode ss3
Is this normal?
Tried to get what i mean in the photos. 1st 3 drivers side. The amber is facing more up cause it hits. Other 2 pics are the passenger side and look fine.
CoronaRaptor
CANADA
I see what you mean. The mounting holes must be too close together for those two lights. Can you drill out the mounting hole, so you can slide the amber over?
CoronaRaptor
CANADA
Is it possible that there is some support frame damage behind your bumper? Are your tow hooks the exact same measurements from those lights? EX: measure form the drivers side tow hook to the outside edge of the bumper, same on the passenger side, that will give you an idea if you need to adjust your bumper or if there are some brackets bent behind the bumper, etc. Maybe I'm off path here too, lol.
Irregular F150
Irregular F150
Nah you may be right, I thought that also. Well i rigged this up, no guarantee this will work with limited up down beam output angle but they fit now LOL!
Oh and to make it all that much better, my phone fell out of my pocket while on the creeper and the screen protector cracked lol
Edit: the bumper is a tad off on the trouble side. Kinda like they put it on a bit crooked, nothing looks damaged.
Irregular F150
Irregular F150
Well theres definitely a difference in angle on the pockets. Couldn’t tell if anything was bent so it may just be a bit off from factory.
Got the cheaper brackets and was able to adjust around the difference in pockets. The led bracket from diode is still not working the best so ill probably end up getting the other style they have. They’re on and useable so good enough for now lol
Members online
93,145
56,419
TwistAir
Latest posts
