Please Read This Before Installing Behind the Grille LED Lights!
Todd Turbo S
Nor Cal
For anyone considering installing LED lights behind their Raptor grille, here’s something I wish I had thought about before installing mine.
A couple of weeks after installing six Baja Designs lights, one failed due to water intrusion after washing the truck. I haven’t driven it in the rain yet, IMG_6186.jpegso I’m not entirely sure how the water got inside.
To be clear, this isn’t a criticism of Baja Designs. They stood behind their product and promptly sent me a replacement.
The real headache was replacing the failed light. I’m pretty particular about my installations, so I had carefully routed all the wiring through protective channels, pulled everything tight, and secured it neatly to the lighting bracket with zip ties. Unfortunately, I left virtually no slack, which meant I couldn’t pull the grille forward far enough to access and disconnect the lights.
What should have been a relatively simple replacement turned into a major project. Between removing the grille, cutting zip ties, freeing up the wiring, and putting everything back together, it actually took me longer than the original installation.
I had also applied dielectric grease to the electrical connections, so I suspect the water entered through the light housing or lens seal rather than the connector, although I can't say for certain.
My advice to anyone planning a similar installation:
1. Consider testing the lights for water intrusion before installing them.
2. Leave enough slack in the wiring to pull the grille forward and access the lights without tearing everything apart.
3. Think about future serviceability, even if it means sacrificing a little of that perfectly clean wiring installation.
The finished setup looks fantastic, and I’m very happy with the lights when everything is working. I just wish I had planned ahead for the possibility of having to replace one.
Hopefully, this saves someone else a few hours of unnecessary frustration.
pastorwug
EMT/First Responder Law Enforcement Supporting Member
Santa Maria, CA
I had so much money in lights when I sold my truck, I thought I'd have time to remove them and put them on my newer truck - nope! Sold in three days!
The more meticulous you are in doing a great install, then the more meticulous (perhaps even more) you have to be in removing them.
All those soldered lines, all the shrink tubing, all the zip ties - endless.
So, I sold all the lights with the truck and got about .50 on the dollar, and of course, nothing for all the labor and meticulous installations.
Sweep-Raptor
SW Missouri
I ran my light bar behind the grill and one of the features was a connector in the wiring harness about 3ft from the bar. This made it super easy to install the light bar and the short section of the harness into the grill and then make the connection after it is fully reinstalled on the truck. 20260709_153955.jpg
Todd Turbo S
Todd Turbo S
Nor Cal
I ran my light bar behind the grill and one of the features was a connector in the wiring harness about 3ft from the bar. This made it super easy to install the light bar and the short section of the harness into the grill and then make the connection after it is fully reinstalled on the truck. View attachment 539807
Nice. I had that same light bar behind the grill on my 2020 GEN two raptor.IMG_2143.jpeg
The Chiz
It is what it is!
Temecula, CA
Just did the squadron pro 2.0 ‘s… she’s stealthy and I like it!
Now that I’m reading some of the forum above, I didn’t even think about servicing them! Ha. It is what it is.!
Nasty
Which lenses did you guys go with?
Spots, Combos, Wide Cornering?
101,289
60,424
HC FabWerks
