Please help
Discussion in 'Ford Raptor Problems and Questions Forum' started by Dan06, Nov 15, 2012.
  1. Dan06
    Dan06 FRF Addict
    1,734
    751
    Oct 15, 2012
    The Dark Side of The Moon
    I have an ADD Stealth Winch bumper. I also have a Roush supercharger. The superchargers cooler is interfering with mounting the winch. The winch is a Recon 10.5. Has anyone dealt with this problem?
    PLEASE HELP! Thanks for any input
  2. c-ne-elk
    c-ne-elk Full Access Member
    228
    83
    Mar 9, 2012
    El Paso, Tx
    While I do not/did not have a supercharger, the way my ADD bumper came from ADD I could not mount my winch. The winch sat too far back and was hitting the condensing unit. But I did have plenty of room to move the winch forward and still have it work.
    So I took the bumper off, welded a new plate betweent the existing plate and the back of the bumper, drilled new holes and remounted the bumper then installed the winch. (you have to have the bumper on before you mount the winch)
    If you do this, a word of caution, watch the angle that your winch gets to. Make sure that your cable/rope from your winch will not fit through the fairlead without rubbing anything else. Mine cleared fine but not by much.
    If yours is like mine, there is plenty of room to move the winch forward (toward the bumper) is there?
Share This Page
