Perch adjustment partial shock removal?
Discussion in 'Ford Raptor Suspension Discussion and Modification' started by Napp E Roots, Feb 5, 2016.
Sponsored By: Fox - Redefining Ride Dynamics
  1. Napp E Roots
    Napp E Roots Full Access Member
    83
    59
    Sep 18, 2015
    Would it be possible to do a perch adjustment by only removing the top of the shock from the shock tower? The the shock could tilt out relieving pressure and allow me to make the adjustment to the middle?
  2. oxfordraptor
    oxfordraptor FRF Addict
    2,437
    2,174
    Apr 11, 2013
  3. Napp E Roots
    83
    59
    Sep 18, 2015
    I tried that method and couldn't get the springs compressed enough they weren't budging amy hints?
  4. no1
    no1 Full Access Member
    520
    708
    Apr 2, 2015
    oxfordraptor likes this.
  5. oxfordraptor
    2,437
    2,174
    Apr 11, 2013
    ^Exactly @JanT knows what's up. It took a couple times to get it right. But work the jack on the LCA and use the weight of the truck. I used $49 Craftsman spring compressors and they worked just fine.
    no1 likes this.
  6. Napp E Roots
    83
    59
    Sep 18, 2015
    I compressed the springs with the weight of the truck and a jack then did the spring compressor and it still wasn't enough I guess I'll try again
    Also is mid perch better than low perch for jumping? I know all the other benefits but no one ever mentions the effects of putting the truck in the air
  7. oxfordraptor
    2,437
    2,174
    Apr 11, 2013
    Yes
  8. Napp E Roots
    83
    59
    Sep 18, 2015
    lol perfect answer
  9. tahitiansoul
    tahitiansoul Full Access Member
    35
    344
    191
    Feb 6, 2015
    Tahiti
    The best first mod to do to your raptor for all.
  10. oxfordraptor
    2,437
    2,174
    Apr 11, 2013
    In all seriousness the truck was designed and tested at mid perch. Regulations forced them to drop the front end for collision. Mid perch is best for off road handling you don't nose plow everything.
Share This Page
