Patent Pending Plug N Play Harness System For ALL Light Models/Brands Including Reverse Lights, Backlights, Marker Lights, Switches and more..
Specialtyperformanceparts
We developed our Plug N Play Wire Harness System about 2 years ago. It was introduced on the Motor Trend Channel in Spring of 2021.
It was so unique, we filed a patent on it. The Patent is in its final stages to be finalized, however, the products are available now.
What makes it so special? Well. The problem most consumers have when installing their lights are understanding the wiring and the manual customization required to splice, and integrate wires to combine lights, add or remove relays and even access factory features like reverse light triggers, Tail Lights, Marker Lights, Parking Lights ETC.
Many will tell you to use a "Fuse Tap". We have Plug In components to add to your headlights, or tail lights with factory connectors that simply plug in to the vehicle and plug into any of our harnesses.
Much like a Lego Set. You can simply pick out pieces and plug them in to accomplish whatever you want. This includes full length harnesses for rear lights that go to switches alone. Or, you can plug in our tail light adapters for automatic reverse triggers for reverse and backlights with the tail/parking light circuit. Or, you can get our short harness to the lights only and our tail light adapter. All of our tail light adapters have built in diodes so there is no back feed to your tail lights.
Each harness comes with a common 3 port connector that can be used with included connectors for lights with bare wires or plugged into our matching adapters to plug into any light model or brand.
We released these kits with popular lights a long time ago. So there are kits for Diode Dynamics, Rigid and Baja Designs. Our Brackets are also universal and can be moved anywhere under the rear bumper. Not just the outer sides. We just think they look better spread out. You can also put them center on each side of the hitch. However, our harness system can be used with any lights. Including FLUSH MOUNTS should you prefer those.
Here are some links to the plug n play rear kits-
Our Fog Kits ALSO utilize our Plug N Play Harness System. Lights with Backlights, like the Rigid Radiance Or Diode Dynamics can utilize our Plug In Headlight Adapter for backlights with the Parking/Marker Lights. While the Diode Dynamics wiring with their Fog kit is complex and confusing. Ours just plugs in. You can connect each light pair to a separate 3 switches. Or you can add our 2 or 3 way splitters at the switch wire ends and plug n play combine them. No twisting wires together. If you ever want to separate them again. You can unplug and rearrange them.
Here are Some of our Fog Kits-
Our A-Pillar Kits are the Same way. If you have backlights, you can use our headlight adapter. You can even share those backlights with our plug n play splitters to multiple lights and light bars with our various harnesses.
Here is one of our A-Pillar Kits-
We also developed new mounting solutions for the Stock Bumper to hold any 40" light bar, including the ONY6 or Full Size Rigid E-Series or Radiance.. as well as our 50" Universal Cross Mount to hold a multitude of light pods you pic.
Here are some examples, bot the cross mount can be purchased with any lights and our harnesses can be added-
When I was talking about splitters and relays that can be added on. Here are some links to those for reference. Our 2 and 3 way splitters can be added to the ends of harnesses to combine them to single switches, or to split connections to backlights from factory marker/headlight/tail light adapters-
Our Light END Splitters can plug into the end of our harnesses to split the end to add 2 or more lights instead of one-
Our Harness End Light Adapters can plug into any of our harness to match any light model or brand (Can be selected with harnesses as a kit too)
Our Relay adapter can plug into any of our harnesses should you need a relay for some extra juice if your AUX switch can't handle it.
Of course we talked about tail light adapters and headlight adapters, but here they are-
We also created some additional kits like our numbered switch wire extensions that you can add to your switch wires for numbered 1-6 wires with connectors to plug right into our harnesses as well as a prep pack that you can add to all wires and pass throughs in your Bronco/Raptor-
Then we have Light bar Harnesses, Fog Light, A-Pillar and Rear Harnesses that can all plug n play and interconnect to any components in the system-
For a basic demonstration of the system. Here is a video clip from its introduction on Motor Trend in Spring of 2021-
Here are some more videos on some of these kits, harnesses and installs-
There is some renewed interest in hitch lights as well. We developed our Hitch light kits for these trucks in 2017. Currently we offer them in the Full Size Rigid D-Series or Baja Squadron. Here is a video and links.
The idea is that these are inexpensive and require no "Installation". You plug them into the 7 pin. You can LOCK them with a hitch lock, and you can remove them when you want to use a trailer...
We would love to hear from you. If anyone has questions, or comments or ideas they would like to discuss. Please reach out to us!
info @spvparts.com
317/934/6778
John
2020FordRaptor
Nevada
https://specialtyperformanceparts.c...s-system-works-with-many-vehicles-see-details
https://specialtyperformanceparts.c...ptor-oem-fog-connector-adapters-others-pair-1
https://specialtyperformanceparts.c...raptor-oem-fog-connector-adapters-others-pair
https://specialtyperformanceparts.c...h-wire-extension-kit-with-connectors-numbered
https://specialtyperformanceparts.c...ire-connector-prep-kit-includes-14-connectors
https://specialtyperformanceparts.com/search?type=product&options[prefix]=last&options[unavailable_products]=last&q=spv+harness+system
info @spvparts.com
317/934/6778
John
That's very neat!
GEN3LV
Las Vegas
Bought a lot of light kits and harnesses form John his products are awesome and make your lighting installs pretty painless. Spoke to him on the phone a few times and he will text back about any question you might have or your order status. Great customer service and great products win win for us Raptor guys.
Thank you for such a kind testimonial! We are always happy to help out in any way we can!
maxr
MT USA
Hey John - Congrats on the potential patent.
Another happy customer. John took the time to answer my questions and I was able to easily install (all Baja Designs) backup lights and in the front bumper cut-out, fogs, combos and spots. The wiring harnesses worked great and everything is tied into my AUX switches. Hardest part was dealing with the horrible way Ford terminates the AUX wires in the engine compartment.
Well worth the money. I live in the forest in NW Montana and the BD lights are a huge improvement over stock.
I have some install posts on this forum.
Thank you for taking the time to leave us such great feedback! I'm sorry Ford's wiring gave you some headaches, but you aren't the first we've heard that from.
If you want to text us over some pics of your truck, we would love the opportunity to add them to our socials!
You can text us anytime at 317.934.6778.
If you do send them and you'd like to be tagged in any future post with your pics, just be sure to leave us your @ when you text them over!
Thank you for allowing us to earn your business and for being a part of the SPV Fam!
BigTaco
Grants Pass Oregon
I’m a very happy customer. The SPV “system” just makes everything simple and clean. My back up lights and rear harness were a great foundation to build off of and everything looks like it was installed at the factory. The no drill bracket kit and RDS pro bar worked out great.
Thats AWESOME! I'm so glad you like it. We try to make the most simplified components for easy install available.
Let us know if you need anything else!
John
maxr
MT USA
that AUX connector kit would have been great to have when I bought my kit from you but you did not produce it yet. Imagine it makes it much easier now to extend and add the plug connector
I am not a social media person but feel free to use the images
We are constantly trying to add to our parts list, and a lot of time updates and additional offerings come about from time, use, and customer input. I'm sorry we didn't have those available at your time of purchase, but that's all part of the growing pains in this business. As time passes, we hope to continue to innovate more offerings to further simplify the install process.
If you ever have any requests, or if you see any area that's lacking in the industry for your truck, please reach out to us and let us know. We always love the feedback and try to come up with things that our customers request.
Thanks again allowing us to earn your business and allowing us to use your images.
We appreciate you!
