andreb
Well-Known Member
Hey all,
I've been having a battery drain issue which seems to have gotten worse over time, it could be my battery (I have not load tested it) but I have found the BCM (fuse panel in passenger kick panel) to be the culprit. It seems like I could not drive my truck for a few weeks before the battery would get low, then it went to a week now it's less than 24 hours. My battery is an Optima red-top that I bought on 8//16/21 so 56 months old now.
I have the hood open with the sensor zip-tied down, the passenger front door open but the catch in the closed position, the truck locked with the remote then the remote inside the house. I start with the battery cable that feeds the under hood fuse panel/power distro connected, lock the truck, wait for the marker lights to go then bridge the battery the main stud terminal in the fuse box with 10 amp DVOM the drop the cable from the positive terminal so all current is flowing through the meter. I also have a clamp-on DC amp meter inside the cab on the power lead the supplies the BCM. I think give the truck 75-90 minutes to go completely asleep.
I the DVOM never reads below 2-3 amps. I use a another DVOM set to 200 DC mv and probe all the fuses. Any fuse that has a voltage drop across it I'll pull and observe the meter. The best I've got is .04 to .07 amps, I think spec is .05. These are the fuses I have removed and what they power according to my ETM Wiring Diagram...
fuse - amps - connected to
9 - 10A - FDIM, FCDIM, FCIM, GPSM, FCIM
11 - 10A - Instrument Panel Cluster
18 - 10A - brake shift interlock, floor shifter, PCM, passive anti-theft, key-less entry pad
24 - 15A - data link connector, steering column control module (SCCM)
29 - 20A - Audio Control Module (radio)
So I can't believe that ALL of these are the problem, I suspect one is keeping the other awake? I've spent hours pulling fuses and measuing voltage drop, I can't seem to fine one fuse that drops all the amps, only this combination gets me down to an acceptable limit. The biggest draws are from 18 and 29, each pulling 1.2 - 1.5 amps.
I am also wondering if I pull a fuse like 9 with all the CM's, then plug it back in - do I need to wait another 75-90 minutes for them to sleep or do I need to go through the unlock/lock cycle to trigger the sleep mode?
Anyone else go through this? I am pulling what little hair I have left out...
