Panoramic roof noise
eclou
Houston
just recleaned mine again, this time using engine degreaser to really get the caked on crud off the rubber seals. Also ran a cloth with a credit card all the way around the rear stationary panel to clean that as well. Lastly put a medium coat of Gummi Pflege on the seals. Dead quiet for now...
usurper
Pittsburgh, PA
I see a lot of discussions about squeaking, but I have a noticeable rattle. Almost like a tapping or flexing. The sound seems like it's coming from the rear panel - has anyone had a similar noise or fix related to the rear, non-moving, panel?
Gary Wren
St Louis, MO
My 19' is making a thunk noise when going over bumps, sounds like two things banging into each other, not a rattle. I think its coming from the back panel too. Thought it was the sunscreen, it seemed to not do it when the sunscreen was open, but that got ruled out after a day. Haven't poked around up there yet to see if anything is loose yet.
Droid
kglesq's Brother
Posted in another similar thread about this....but adjusting height of fixed panel cured it on mine (six T25 bolts, three on each side). I put the front of the panel in a mid position and the back as far down as possible....the back being in the bottommost position was critical to eliminating my noise. I also no longer see water going into the drip channel during a carwash.
Try and find a good section of rough pavement to reliably/repeatably test changes with and make adjustments.
Solidred
So. Cal
ive made a few rear fixed panel adjustments but can’t get that rattle/thump to stay away. Can you post a couple pictures from the outside on your glass placement
