P07AA:00-6C
MX71
Scottsdale, Arizona
Help! Facing some tranny issues whereas the truck will shift erraticaly across all 6 gears and then periodically hit 1st gear at speed causing the tires to chirp and vehicle to get sketchy. (Recall symptoms)
So I did the following...
1) Had the reprogram performed by Ford (Did not fix issues)
2) I changed out the Lead Frame, fluid, filter, etc. (Did not fix issues)
Not sure what to do at this point, so needing some guidance on next steps before I drop $4400 on a new tranny build.
Thanks!
MX71
MX71
Scottsdale, Arizona
Totally a possibility. The harness is missing the flip down lever to lock it into this sleeve. I wonder if it not getting a good connection?
FordTechOne
Detroit
Harness latches are critical to circuit integrity, and low voltage/loss of voltage to the shift solenoids will cause a variety of issues. Get that repaired before going any further. Motorcraft sells a replacement pigtail, part number is WPT-1390 per the Workshop Manual.
MX71
MX71
Scottsdale, Arizona
Well end result is new tranny something mechanical is broke. Was able to have Ford match tranny shop and extend coverage for 3 years unlimited mileage. Not ideal but I suppose I know what I have now. Thanks for all your help.
If anyone needs a leadframe the one I took out is good and incan ship it to you.
Matt
