P0454 Code - Evaporative Emission Control System Pressure Sensor Intermittent
Discussion in 'Ford SVT Raptor General Discussions [GEN 1]' started by Christyle, Oct 19, 2020.
  1. Christyle
    Christyle Full Access Member
    81
    88
    Dec 16, 2019
    Chino Hills, CA
    Anyone get this code? Popped up twice on me, but only when in AZ backing down a launch ramp it seems. Never gotten it otherwise. Usually clears after a few key cycles... I didnt find a single post on here about this one, which was very surprising for one of two reasons: Nobody has posted about this issue, or I can't search. Neither seem believable, but here we are...
    Anybody run into this one?
  2. MTF
    MTF FRF Addict
    4,567
    1,369
    Nov 27, 2010
    NYC
  3. Christyle
    81
    88
    Dec 16, 2019
    Chino Hills, CA
    Thanks for the help. Can you tell me what exactly I'm doing wrong on the search?
    The thread looks to be about other codes, but it reminded me that my truck will occasionally leak fuel when I fill up the tank. As in the nozzle shutoff kicks it off, and then all of a sudden a bit of fuel ends up spilling out. I may have to look into the fuel filler to see what the issue might be and see if it's related.
    I had found that webpage you linked as well, but it didnt give me the magic link to the definitive part number or youtube mechanic fix-it video I was hoping for.
  4. MTF
    MTF FRF Addict
    4,567
    1,369
    Nov 27, 2010
    NYC
    You're doing nothing wrong, it's just sometimes the search tab on the forum does give all the results dating back to the beginning of the forum.
    From reading a little bit from autocodes.com it seems more of electrical issue,
    I guess you're going to have inspect all the connections related to it.
    I never got that code so I don't know much about going about tracing it down.
  5. nec9
    nec9 Member
    11
    16
    Oct 12, 2020
    PNW
    I got a P0456 EVAP small leak code. Probably similar. Its either the capless fuel seal or the canister purge valve. I bought a new cpv, 10 minute install. CEL gone. But I was getting start up issues when refueling which was a telltale sign of the cpv going out.
    BenBB and Christyle like this.
  6. Christyle
    81
    88
    Dec 16, 2019
    Chino Hills, CA
    I'm not having any issues now, so I'll just leave it be until I have some actual problem symptoms to track down
  7. B E N
    B E N Full Access Member
    618
    361
    May 1, 2019
    Frederick, CO
    When your searching for something really specific google works best, try this:
    pressure system intermittent site:www.fordraptorforum.com/
    If you want to make it more specific to your vehicle you can add +2013
    That + symbol will tell google it must contain the year 2013 limit it to gen 1.
    Since there isn't a lot on this forum just expand the search to global and use f150, then end the search with the word forum
    pressure system intermittent +f150 +2013 +forum
    First post on that search returned a fix https://www.f150forum.com/f38/intermittent-oil-pressure-2012-platinum-ecoboost-337562/
    Strengthen your googleFu!
  8. Christyle
    81
    88
    Dec 16, 2019
    Chino Hills, CA
    I appreciate the assistance, and I'll try some of those combos, but that's an oil pressure issue, not the evap system issue. I've googled a lot of different combinations of things as well and haven't had any luck, hence me coming here to search.
Share This Page
