As the title suggests, I over-torqued the ball joint nut on the tie rod end. I put a flex handle on it and it was on there tight. So I put some muscle into it. Got probably 1/2 to a full turn on it and it became harder. Well wouldn’t you know it I was indeed tightening it, long day.......... spun it the other way and it came right off.
Would you imaging the knuckle would crack or the ball joint yield first? I know that it is “likely” fine but I tend to worry about stuff like this and figured what better place to ask for opinions then here.
I looked for damage to the threads on the ball joint, looked and didn’t “see” any cracking on the knuckle. Anything else I should look for?
I hope I didn’t do any real damage as even though I like SDHQ’s reinforced knuckles I don’t think I am ready for them.
Thanks.
Thanks.
