One Mod. Massive Difference. Bronco Raptor Roof Light Bar PRO
MandR Automotive
Forum Members Get 10% Off! Use the Discount Code “FordRaptorForum” At Checkout
Looking to add serious nighttime visibility to your 2022+ Ford Bronco Raptor without sacrificing the truck's aggressive factory styling?
M&R Automotive's Roof Light Bar PRO was designed specifically for the Bronco Raptor, featuring a low-profile 40-inch curved LED light bar that hugs the roofline for a clean OEM-inspired appearance. The kit is completely vehicle-specific, reuses factory mounting points, and is compatible with both hard-top and soft-top Broncos.
What makes this setup stand out is its sleek fitment. Unlike many roof-mounted light bars that sit high above the windshield, the PRO kit is engineered to stay close to the roof while helping reduce wind noise and maintaining a factory-style look. The kit includes powder-coated brackets, mounting hardware, and a bolt-on installation with no drilling required.
Key Features:
  • Fits 2022–2026 Ford Bronco Raptor
  • 40" M&R Automotive PRO Series curved LED light bar
  • Low-profile roof-mounted design
  • Works with hard-top and soft-top models
  • Reuses factory mounting locations
  • No drilling required
  • Available in White + Amber DRL or Yellow + Amber DRL configurations
  • Lifetime warranty
  • Designed for off-road use only
Want to see how the installation is done?
If you're building your Bronco Raptor for overlanding, trail riding, desert runs, or simply want a cleaner alternative to traditional roof lighting setups, this kit is definitely worth a look.
What do you think—roof-mounted light bar or bumper-mounted setup for the Bronco Raptor?
For off-road use only.
101,284
60,415
Gerth
