Anybody happen to know the part # for the oil drain access panel bolts (10mm) and u nuts on a Gen 2 (2019)? I can find the skid plate stuff all over but can't even find a picture of the oil drain access panel?
Thanks!
Thanks!
Thanks, much appreciate it, the u nuts are the few that are that size. All the skid plate bolts and u nuts are quite a bit bigger.I think its one of these 2 I can double check tonight when I get home.
w717461s439
2017-2023 Ford Skid Plate U-Nut -W717461-S439 | TascaParts.com
2017-2023 Ford part # -W717461-S439 - Skid Plate U-Nutwww.tascaparts.com
or
w717634s439
2010-2020 Ford Front Shield U-Nut -W717634-S439 | TascaParts.com
2010-2020 Ford part # -W717634-S439 - Front Shield U-Nutwww.tascaparts.com
I bought 4 of each because I couldn't figure out which one I needed. I had the same part break.
Hi, did you determine if one of these was the right one? Thanks!!I think its one of these 2 I can double check tonight when I get home.
w717461s439
or
w717634s439
