Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
We just picked up a nice 2013 Raptor. When trying to get the off road camera to work (yes in off-road mode, 4L, enabled, D, and less than 15mph) all we get is the view from the back up camera. Any ideas?
check to see if theres a nav tv unit in there. if there is, it interfaces with the front camera and if the nav tv module has rattled loose or cable not properly connected, it will default to the rear camera when trying to turn on the front camera
sorry. to check to see if theres a nav tv unit, push the rear defrost button twice. if the rear camera shows up, then theres an interface there and would be best to start at that point. if there is no nav tv interface, then theres probably a camera issue
