In case any were debating getting a center console safe, I have attached a pic of the OEM safe I installed so they could see what it looks like.
Anyone with experience on how the OEM compares to TuffY? $150 vs $329 is quite a difference. Ford F150 Security Console Insert for 2015+ flow-through center console
As someone mentioned, it was around $325. Yes, my tray is inside the safe currently. I don't know what the Tuffy has as far as an opening mechanism or its size. I wanted to make sure it had a combo and NOT a key. It's much easier to open in the dark or not looking at it if you just have to change one number on a combo as opposed to trying to dig out a key if you need to get your gun out. An agent I work with has a key one and he's getting rid of it and getting the OEM one I have listed here for the same reason.
Curious......How does it mount to stop a thief from removing the whole safe? Thanks! Sent from my SAMSUNG-SM-G935A using Tapatalk
Its bolted/screwed down from the inside so you cant just pull it out or undo anything unless you know the code and its open.
