Oem rear shock lower bolt torque?
M_NorthRaptor
British Columbia, Canada
I am getting ready to install my swarfworks lower shock guards and was curious to know if anyone has the torque spec for the lower shock bolt. Have not had any luck finding the torque spec so all info is greatly appreciated.
2019 raptor
Dustan
Boulder Colorado
75 ft lbs left side and 66 ft lbs right side. This is from the fox 3.0 install instructions. I sheared my right side bolt while installing the swarfworks shock guards due to not paying attention to torque numbers.
amREADY
Victoria, BC
Did you use the OEM bolts? I'm about to put mine on and it seems like the OEM bolts aren't quite long enough (on a 19)... I'll know better once I'm into it.
