trayack
I've been having the following issue on my 2013 Scab with OEM HID's for several winters now.
Once the temp drops below 50ish degrees or so the driver's side high/low flapper will get stuck up in the high beam position. As long as the temp is in that range the only way to get it to drop back down is to pound your palm against the light which will drop the flap back down into the low beam position.
Anyone else have this issue, and if so, how did you fix it?
Not looking to spend 100's if not $1500 on a new set of lights over a seemingly simply issue.
- Travis
- Travis
