GEN 1 Oem front shock parts
Jhollowell
Everett, wa
Does anyone know where i can buy parts for our front shocks? I’m looking for the rubber bumpers that go on the shaft, top hat (part that holds the coil on the shock) and the plastic piece that fits on the perch. I bought some used shocks that I’m having rebuilt and I’m installing Geiser springs on those so I’m trying to figure out if it’s easier to buy those parts so i can assemble the shocks 100% and just swap or if i should buy a spring compressor and pull my stock springs off to get the parts i need
J DAMAGE
NJ
Doing the same , here's some part numbers:
SHOCK MOUNT- AL3Z-18A099-A
INSULATOR-----7L1Z-5415-A ,
Im replacing the shock mount, but have to wait to take my old shock apart, I cant see spending 100.00 on 2 rubber isulators.
If I looked a little harder, I could have used MONROE 906963, SHOCK MOUNT AND INSULATOR for 47.79 form ROCKAUTO
This link shoud have the whole break down with part #
https://www.oemfordpart.com/auto-pa...ont-suspension-cat/struts-and-components-scat
Jhollowell
Jhollowell
Everett, wa
Thanks man!! I’ve been looking for a part breakdown like that. And yeah the rock auto ones look good. Just need to find that plastic spacer that goes on the perch. Although a spring compressor is only 100 bucks so it may be cheaper to just buy the tool and swap parts.
J DAMAGE
NJ
I bought new front and rear shocks from Rock auto, purchased new shock mounts, and shock mount nuts, figured I just do R/R , then I realized I forgot to order insulators, but glade i did for almost 50.00 each. degassed the new shocks to install shrader valves, hoping to charge them this weekend and start install. But with work hard to say when it will happen.
Jhollowell
Jhollowell
Everett, wa
Thanks guys
I was looking at your site and found a few of the parts although the pictures didn’t really match. I’ll give you a call later today.
Cheers
SDHQ
GILBERT, AZ
Thanks guys
Cheers
Working on getting that all updated right now as well as adding more parts.
Chinmasterflex
Las Vegas, NV
Even if you buy from someone else, I find the parts diagrams and associated part numbers from tasca or other online dealership based/associated parts supplies pretty darn helpful for this kind of stuff
Jhollowell
Jhollowell
Everett, wa
Ordered the spacers and bumpers from sdhq. Good prices too. Found the top nut on eBay for pretty cheap. Just waiting for the shocks to get back from rebuild now
Viperi
I'm looking to do the same. I have the front shocks and eibach springs.
Anyone got part numbers from rockauto or ford for everything including the nuts to be put together to do an easy swap?
101,072
60,256
calspajamas
