RC51TOFUMAN
Taking a trip down to San Diego area Monday to dropoff my extra set of OEM Fox Shocks to have them serviced at Fox Service Center
Any recommendations/ suggestions?
Copy will doObvious stuff like check your ball joints for wear, brake lines, maybe a good time to go stainless steel. Check your sway bar end links (cheap to replace). In the rear I would clean the rear springs with a pressure washer while you have it jacked up at full droop and let it dry, they if you are in an area with road salt, you could spray fluid film on the springs and frame, etc.
Still waiting on mine to get completed from FoxFox did me right, Its the only place id have OEM's rebuilt after going through a bunch of hassles with so called rebuilders
