Quick update: Really not much to update. I haven't really done anything besides drive this thing most days. I was still having moisture on the passenger side floor board so I dug into it a bit more. I pulled the 90 degree rubber fitting that the dealer installed as part of the TSB and applied some clear adhesive silicon all around the little nipple that protrudes into the engine bay. I have ran the A/C quite a bit since then and haven't experienced any moisture. I've checked it at least 10 times and I've checked it by reaching up and feeling all around the area where the drain passes through the firewall and into the engine bay. there is this little carpet like cover that normally gets wet, but I haven't felt any wetness. But it really hasn't been hot enough here in Ohio to be hot enough outside to tell if it's really working.
The dealer got back to me about a week ago saying the claim for the repair of the hvac box and evaporator was approved and is $6500. It requires a full dash pull and I really don't love that. I told them I want to wait until the spring / summer to test out the a/c "fix" I made unless they wanted to do some more actual diagnosis. The service advisor has honestly been great to work with and I feel like we've both been able to be very transparent with each other. I explained I don't want the dash pulled unless we absolutely know it has to be to fix this problem. To my surprise, they told me to drop it off today so they could do some more diagnosing. One of the things is adding dye to the A/C refrigerant to check for that leaking inside the passenger side floor. I'm 99% sure that isn't the issue because with as much as it's leaked the past couple months, the a/c just simply wouldn't be operational. They are going to try and check the gasket at the firewall where the a/c water drain lines exit out to the engine bay. I have a feeling that is probably a better chance of what the actual root cause is. But that still requires a full dash pull
Should know something more today.
Only other issue I'm having is that I am now getting a recurring P0430 CEL. I've cleared it several times now but it's continuing to pop up. It's odd that it is popping up now after having the CVF catted DP's on the truck for several months so I think I may have a legitimate issue somewhere.
