OEM++ 2019 Raptor Build
jfisher99
jfisher99
ohio
How was (or is) the comparison from stock brakes to your new wildwoods? I’m due on new brake pads (and maybe rotors) soon so I was going to look to aftermarket options.
I honestly haven't stood on them to really tell, but @Waterfowler41 did an actual before and after test and the truck stopped quite a bit quicker than the stock brakes. I also noticed a tiny bit more touchiness to the brakes which I find to be a positive as the stock brakes aren't as sensitive as I like brakes to be.
jfisher99
jfisher99
ohio
Got the CVF Downpipes installed over the weekend. The downpipe install itself was super easy, but getting the stock rusty exhaust off was an absolute nightmare. This was even with dropping the cross member which I did immediately. It was only 9 total bolts and came off quickly. I've done aftermarket exhaust on pretty much every vehicle I've owned since the beginning of time and this was probably the worst un-install I've ever dealt with. I'm also getting too old to be working in the garage on my back lol. I was unpleasantly surprised at how crusty the stock exhaust was (primarily the hardware), but even the piping was just in bad shape. It's odd because the rest of the underside of the truck is in great shape.
I ended up just cutting up the stock exhaust to get it off. The condition of it isn't worthy of ever being put back on the truck so I ended up getting the sawzall out and going to town. I was real nervous about getting the stock studs out of the turbos as I had one break off on my son's Fiesta ST when we put a downpipe on that, but with the stud removal tool and some heat, all four of them came right out with ease.
I ordered up a Evil Energy 2.75" stainless exhaust clamp as the stock one was so rusted I had to cut it off. I am pleasantly surprised by the additional sound I got with these even with the rest of the exhaust being all stock. I could immediately tell the truck was a tad louder at idle, but at WOT the truck is definitely louder. I did the 10 minute break in procedure CVF calls for and checked all the hardware over for tightness this morning just to make sure nothing was backing out. The evil energy clamp had already shifted forward a tad and created a tiny exhaust leak. I can already tell I'm not a big fan of that clamp so I may looking at having a local exhaust shop do a v-band clamp instead. Maybe it'll give me a reason to go with the SPD trombone resonator delete pipe instead...
Downpipes with the secondary O2 spacers.
Crusty clamp from the driver side downpipe to the resonated stock mid pipe:
Downpipes on:
jfisher99
jfisher99
ohio
Yesterday was a good day. Not only did I get my E85 tune from my tuner, but I also got my tracking number for the TSW rebuilt shocks yesterday. Those should arrive on Monday. Can't wait to see what the wheels and 37's look like on the truck and to see if they actually fit.
Will get the E85 tune loaded up today and start adding some E. This thing should rip even more than it already does.
Wife also captured a quick rip with the downpipes
jfisher99
jfisher99
ohio
Dropped the truck off at the dealership today for a couple warranty / tsb issues. I started getting some wet carpet under the front passenger side floor mat. It sounds like the TSB for the a/c drain, but I'll let them figure that out. I also have some creaking occurring from the sunroof after I close it. The side rails failed on my old 2017 F-150 Lariat, but I don't remember this creaking noise.
Ceramic coated the new wheels using GTechniq's C5 wheel armour. PITA to do on these wheels, but I'd much rather do this now then have to clean the little crevices in the wheels all the time. Curious to see how this stuff performs as I've never ceramic coated a set of wheels before. Will probably do the Wilwood calipers when I have the wheels off again:
jfisher99
jfisher99
ohio
Figured I'd go ahead and weight the wheel and tire combo while I was at it.
-Weld Ledges in 18x9 +0 came in right at the 29.4 lbs as advertised
-Nitto Ridge Grapplers in 37x12.50x18 came in at 80.6 lbs
Total is 110lbs for wheels and tires. Looks like the stock KO2's and beadlocks are in the 101ish lb range. I did buy Atomic Black Titanium GR5 M14x1.5 60* lug nuts as well so hoping that saves about 3 lbs compared to the stock steel lug nuts (65 grams per lug nut on the stockers to 38 grams per lug nut on the Atomics). Should be roughly around 7lbs heavier per corner with the wheels, tires and lug nuts:
BRUCE_MT_GEN2
Billings, MT
Did you look into the Alcon brake kits as well?
jfisher99
jfisher99
ohio
These beauties showed up yesterday. Started the install of the front right shock and of course the solenoid caps are seized so made a call today to TSW to get some replacement caps overnighted. Will snag some pics of everything when completed. I have a feeling the nose is going to be a tad higher in the front. Rear leafs may be in my short future.
jfisher99
jfisher99
ohio
These will be used with FMI 2" HD top hats in black. Very nice pieces. I went ahead and installed the provided studs with some blue loctite. Saw this tip on a YouTube install video as it's possible for the top nuts to start backing the studs out when torqued to the required 30 ft/lbs.
FMI Top Hats 1.jpegFMI Top Hats 2.jpegFMI Top Hats 3.jpegTSW Shocks and FMI Hats.jpeg
jfisher99
jfisher99
ohio
Front shocks and top hats are installed. A couple pointers for those that are thinking about doing this:
1) Go ahead and buy solenoid caps. Both fronts were completely seized and truck is down until I can get some in from TSW. They have been great to work with as they're overnighting me a set of four stockers because the billet aluminum caps won't be back in stock until next week.
2) I would also just go ahead and buy new strut shaft dust shields. Both of mine ripped when removing from the top hats and have now completely separated from the upper top hat perch. I really can't think of any work around besides just ordering these and basically doing this job over again. Not the end of the world, but would have saved me a lot of time and headache over a $70 purchase
I'm in a unique situation where my garage is currently being taken up by my 1998 Cobra I am selling. I live in a neighborhood with an HOA so I really shouldn't be working on the truck in my driveway at all, but it's my only option right now haha.
3) The Dirt King caster / camber bolt kit is nice. It really kills two birds with one stone because loosening up the lower control arm bolts to install this kit also allows the control arm to drop with ease for the installation of the new shocks.
4) Straps to hold the spindle from falling over is a must. My brake lines aren't long enough to allow the spindle to fall to the side when detached from the upper ball joint and tie rod.
5) I know I need to drive the truck to allow the springs to settle a bit, but I have a feeling this thing is going to be nose high :( My research indicated that a 1.75" SDI top hat left the front end just slightly low in the front end by about 1/4", but this thing is sitting really high right now with the FMI 2" hats. There wasn't much information on FMI top hats as they're not super common on these trucks so doing basic math I assumed I'd be perfectly level. Not feeling warm and fuzzy about this as of now. Solenoid caps should be here tomorrow and then alignment and tire install on Friday.
TSW Fox Shock Install 3.jpegTSW Shock FMI Top hat 2.jpegTSW Shock FMI top hat 1.jpeg
jfisher99
jfisher99
ohio
All loaded up and ready for the wheel / tire install and the alignment. I am definitely going to need to do some rear springs as the truck is currently nose high. Need to do some research on deavers vs icons. I definitely like the simplicity of install of the deavers, but like the adjustability of the Icons
Wheels and tires installed. Really happy with how this turned out. I'm glad I went with 18's as you can tell they're not 17's, but they're also not too big looking like a 20":
jfisher99
jfisher99
ohio
This is where we netted out with the alignment. I am going to have to do some very minor plastic trimming, but overall I would say this was a success. I've been driving the truck since the wheels and tires got installed on Friday and I have very minimal rubbing on each side when going full lock:
jfisher99
jfisher99
ohio
It's impossible to really tell what the top hats, shocks and / or tires did, but the ride quality is noticeably stiffer, but in a good way imo. If anyone has ever installed Bilstein 5100's on previous trucks I would compare it to that. It's a firmer, but more planted, confidence inspiring feel. Some may not like it and want the absolute softest, smoothest ride, but I still think this truck delivers a really nice ride quality, but with a sporty feel.
Future mods planned:
-SPD Trombone pipe
-New rear leafs
-CarABC radio, but only until they get the software figured out on the closing screen
Other than that I just plan on driving and enjoying this thing. Really happy with where it is right now and still love driving this thing every day.
jfisher99
jfisher99
ohio
Haven't had a lot going on with the truck besides just driving it and dialing in the E85 tune with my tuner. From a stop this thing runs really well and is pretty raw. The 2nd and 3rd gear shifts hit the tires so hard and it is definitely an interesting sound when chirping a new set of Nitto 37's vs the previous BFG KO2 stockers. I was actually concerned at first, but have gotten used to it after doing multiple logs.
I did make an offer on a used set of Morimoto 4 banger fog light kit that were well used. I'm currently in the process of tearing them down completely and refinishing them. The stupid carriage bolts that came with them are also getting replaced with some nicer hardware (the brackets showing bare metal below are because I had to cut 3 of the carriage bolts off as they wouldn't stay seated in the brackets to remove the nuts). The kit did come with the Morimoto wiring harness which is really nice and all I really have to do is run the power cable to the battery, find a good ground spot (more than likely the battery), mount a pair of relays and tap the switch wire into one of my Aux wires. I was hoping to be able to turn on different fog lights with different Aux switches, but this harness makes everything so simple I really don't want to tear into it at this point. More to come
jfisher99
jfisher99
ohio
Was able to give the truck it's first hand washing. I'm not used to washing a bigger vehicle like this truck as I usually run them through Mikes carwash. I've only been hand washing my 1998 Cobra the past several years so washing this thing took a lot more time. The Ford Performance Blue looks really good when it's clean. But it definitely could use a paint correction. I'll be digging out the TorqX Polisher before the winter and giving this thing a good polish and seal.
jfisher99
jfisher99
ohio
What outfitter switch are folks using for their fog light installs? This Morimoto kit came with a plug n play harness that also includes a pair of relays. I know it won't take a bunch of juice to trigger the relays (the NCS pod lights are 1.5 amps per light so 9 total amps), but which is the best fit (15,10 or 5)? I've got an email out to Morimoto asking this and asking for the installation instructions, but I'd like to get these installed tonight as I've got a free evening.
101,284
60,415
Gerth
