Odd Rear Camera Malfunction
Discussion in 'Ford Raptor Problems and Questions Forum' started by vorlonkosh, Apr 26, 2017.
  1. vorlonkosh
    vorlonkosh Member
    3
    Apr 26, 2017
    I had an odd malfunction that just start occurring with the rear camera system. I am not sure if it is software or hardware related. It is intermittant, and didn't repeat itself when I took it in to the dealership to check (of course). They told me the camera was quite expensive to replace, but I am not convinced it is a camera problem. It could be, but I would think that if the camera in the tailgate was bad, it simply wouldn't show any picture at all, or a badly obscured one at best. This malfunction seems like it is software related. The problem is that 50% of the time, the rear view display is "flipped" and the guidelines vanish. What I mean by "flipped" is that the image is a mirror opposite of what it should be. Objects on the left, now appear on the right and vice versa. The view also has a "fisheye" look about it with distortion around the perimeter of the image. I have attached a file that shows the same backup view with and without the malfunction. Has anyone else seen this malfunction? What was the eventual resolution and what guidance would you suggest I give the mechanics when trying to diagnose the problem? I don't want this issue to get the shotgun approach and end up replacing a bunch of stuff that really didn't need to be.
    Any help or advice would be appreciated.
    Thanks!
  2. pjones
    pjones Full Access Member
    51
    662
    407
    Jan 7, 2017
    Your truck may be thinking there is a trailer attached.
  3. Ruger
    Ruger FRF Addict
    6,155
    4,536
    May 16, 2011
    Northern Nevada
    The guidelines on my truck have occasionally disappeared, but the image doesn't mirror-image. Resetting the guidelines is a simple matter, of course.
  4. vorlonkosh
    vorlonkosh Member
    3
    Apr 26, 2017
    Tried to reset the guidelines several times to no avail.
  5. jbounds
    jbounds Member
    5
    Jan 9, 2015
    Frisco Tx
    Sorry to comment so late, but I have the exact same issue. Did you ever get it fixed?
  6. Fusco0520
    Fusco0520 Full Access Member
    32
    159
    70
    Jan 29, 2017
    I had that issue on my f150. They replaced the camera and it fixed everything.
  7. vorlonkosh
    vorlonkosh Member
    3
    Apr 26, 2017
    Yes, to the tune of about $800.00! The camera was replaced in the end. Very disappointed.
  8. Fusco0520
    32
    159
    70
    Jan 29, 2017
    I was lucky to have it done under warrenty.
Share This Page
