Odd noise when turning right?
EmbDriver
Phoenixish
So I got this odd noise only when turning right and just starting out, like at a stop sign....sounds like a heat shield or something like that, or dust shield hope it isn't an IWE issue...anywho, I am stumped, any thoughts appreciated!
Dane
Littleton, CO
My two thoughts are exactly what you said. Dust shield (done this myself) or IWE issue. Dust shield is easy to bend when doing shocks or maybe brakes. It's also super easy to bend back without disassembling anything - so I'd get in there and look or bend it out.
Conversely, if that isn't it and it's easy to reproduce your noise, disconnect (and temporarily plug) your IWE line on the right side. This will fully engage your IWE. See if you still get the noise or not. If it does, you have an IWE or vacuum line issue.
EmbDriver
EmbDriver
Phoenixish
ya I just adjusted my dust shield drove her around for about 10 miles noise returned pulling into my house.... Thank you Dane! Appreciate the intel
Dane
Littleton, CO
Well damn. Dust shield is the easy one.
Another possibility, if you've changed brake pads recently you can put them in wrong and you can make contact with the wheel or wheel weights. I suppose a wheel bearing is another possibility, though at this point I'd bet on IWE/vacuum line issue. The vacuum line isn't bad to replace, not spendy either. IWE isn't much fun though.
EmbDriver
EmbDriver
Phoenixish
Ya I have been reading all about the IWE system today, solenoid, oneway check valve, lines in general etc etc...that being said with the lines themselves I see that Forged Offroad makes a 100% silicone version of the traditional vinyl/rubber lines is the $150 price tag worth the price of admission or just go OEM?
IHAVETWO
NY
DID YOU INSTALL FLAPS?MY 17 HITS SCREWS FOR FLAPS WHEN I BACK OUT OF MY DRIVEWAY TO THE RIGHT.
EmbDriver
EmbDriver
Phoenixish
negative on flaps it's definitely front PAX side, sometimes now even straight line under load:mad:
EmbDriver
EmbDriver
Phoenixish
well just ordered new fomoco IWE lines, new solenoid, and check valve....thinks that's a good start
blsstrongarm
Illinois
Check the rear dust shield too squeaking drove me nuts on mine for over a week before I figured it out. must have bent it a little doing brakes doesn't seem like the back would flex that much when turning but it does
Trick.Raptor
The Cracker Raptor
Santa Maria, CA
The Forged Offroad silicon lines are truly plug and play and while it costs more than OEM its an upgrade that will last far longer than OEM lines. Several people use them without complaint :)
