Help SupportFord Raptor Forum by donating:
Help support Ford Raptor Forum :
O2! sensors
Discussion in 'Ford F-150 Raptor General Discussions [GEN 2]' started by pavz, Jun 24, 2019.
  1. pavz
    pavz Member
    May 29, 2012
    Hi Can anyone help with this.
    I have a 2017 Gen 2. I have bought new sensors as well, still I keep getting the two DTC CODES.
    Has anyone been thru this.
    2017 Gen 2
    9200 Miles.
    Thank you.
  2. SilverBolt
    SilverBolt Hired Gun
    2,464
    975
    Jan 12, 2011
    Portland, OR
    Why are you buying/replacing O2 sensors? This is warranty work. Your emission warranty should be 5yr/50k miles.
    Jace21583 likes this.
  3. 1BAD454SSv2
    1BAD454SSv2 Full Access Member
    98
    58
    Jan 8, 2019
    HELL I ZONA
    Try changing gasoline brands , see if it goes away. Once every few months i would happen to fill up with Shell gas and 50 miles or so later i would get catalyst effciancy codes every time.
  4. nfsraptor
    nfsraptor FRF Supporting Member Supporting Member
    96
    32
    Nov 7, 2018
    SoCal
    I got those exact same codes a while back and took it under warranty turns out I broke a sensor and something else on a run but they fixed it under warranty.
  5. cddawgs
    cddawgs FRF Supporting Member Supporting Member
    85
    35
    Dec 3, 2018
    Macon, Ga.
    PLEASE enlighten me. How is it you are getting codes. The question is not about any particular code, how is it you get codes period? I have no idea if Ive ever gotten any kind of code at all. Are you running a diagnostic somehow? Does our truck tell us there is a code? How are you getting codes, regardless codes of "what", just codes. what am I missing?
  6. Thomas H Walker
    Thomas H Walker Member
    10
    3
    Dec 5, 2018
    Starkville, Mississippi
    I had exactly the same problem. Was getting the Yellow "Service Engine Soon" idiot light. Took it in and the Dealer ran the codes and got P0420 and P0430 which they said indicate the Catalytic Converters were bad--both of them. No one believed that since the truck had less than 10k miles on it. So, they reset the codes, but a couple of weeks later they came on again, and stayed on. Went through this several times, taking the truck back to the Dealer multiple times where they checked everything including the O2 Sensors. Finally, they just replaced the two Catalytic Converters under warranty. I mentioned the O2 Sensors but they told me the sensors for the Catalytic Converters were integral to the Catalytic Converters. Since then no Service Engine Light.
    Only thing anyone can figure is I was getting most of my gas at a Commercial Station that sold Non Ethanol Gas. They sell lots of Regular, but probably very little Premium, which is what I was using. Possible they got contaminants in the Premium Tank which because it didn't turn much I was continuing to use. I now buy gas (Premium Ethanol) from stations where I know they get lots of turn on their Premium Tanks. Usually it's Shell.
  7. Turbo95max
    Turbo95max Full Access Member
    39
    149
    27
    Jul 20, 2012
    San Bruno, South SF, Petaluma
    Most of the time P0420 and P0430 codes are cat related. We see alot of people change their O2 sensors hoping it will fix the issue and end up getting new cats. Your car should still be covered under warranty so don't worry about it and bring it to the dealer.
Share This Page
