No power to fuel injectors
jwhull
New York
Does anyone know where I can download a wiring diagram for a 2012 with 6.2. Need to figure out where injector power comes from. From what I have read there should be 12 volts on the power side of the injector plug and the PCM puts a ground on the negative side when it needs to open.
J
jwhull
New York
Crank no start, no power to injectors with key on. Trying to find a wiring diagram that will show where injectors get power from.
FordTechOne
Detroit
The injectors receive power from the fuel pump relay, which is controlled by the BCM. The FP relay also powers the Fuel Pump Control Module. Fuse F66 in the BJB (underhood fuse box) provides power to the FP relay, and BJB Fuse F68 powers the control side of the FP relay.
