GEN 1 No 4wheel drive
beadblaster
Grand Forks, BC, Canada
Out of the blue my 4 wheel drive quit working. The hubs are engaged when truck is turned off and disengage with engine running like it suppose to do. With 4x4 switch to 4 hi ,engine running , drive shaft does not turn and hubs are locked. With just the key on and engine not running you can hear the transfer case shift motor click on. Could the shift motor be clicking and not actually engaging. Any ideas.
Dane
Littleton, CO
What you've stated would be my bet. Transfer case isn't actually engaging the front drive shaft. What does 4 low do?
Good job troubleshooting. You read up on IWEs first!
Dane
Littleton, CO
When I put it in 4lo is stays in 2 wheel drive but in low range. I just replaced the iwes for the sixth time.
Well, I agree that it sounds like your transfer case - and that sucks.
Regarding your IWEs, have you looked into the thicker RCV rings? After replacing mine multiple times I switched to those rings and haven't broken them since. Won't help your transfer case issue though, sorry.
Curt Kautsch
North Texas
I can provide some input here. Either one, or all of the below fixed my very similar problems discussed above:
1) I replaced the TC motor. I adjusted the torque spec to the required 89 in. lb. on all 4 bolts (i think this is critical)
2) I would suggest this to everyone. REMOVE the IWE system all together (Even you Gen 2ers). I understand that it may cause minor premature where, but Ford is the only manufacturer with this system to gain as little MPG to appease the EPA (to my knowledge). The system is garbage and needs to be gutted. (I suggest RCV rings for this $150/pair). 1 hour job if you are mechanically savvy at all.
3) User Operation and sequence of engaging 4L is critical as well. First come to a COMPLETE stop, even letting the motor and gears to spool down completely while in neutral. Second, shift in to neutral (if the cluster indicates "shift delayed, pull forward" DO NOT shift to drive as this confuses the system. Give it a few seconds to engage, and lastly and most important DO NOT depress the brake at any time as this will also disrupt the sequence and it engaging properly. Yes you will hear a slight "clunk" when engaged, this is normal. Follow the same procedure to disengage.
Hope this helps someone....
