RangerRob
Its been a long time since I've posted on this forum and I'm in need of some help from the programming/wiring gurus out there.
Recently I had long travel suspension installed on my truck. The suspension is basically a Blitzkrieg 4wd long travel kit with King 3.5 bypasses, 2.5 coilovers, and 2.5 bumpstops. This suspension is not a bolt on kit and requires a lot of fabrication. With that being said, the fab work involved requires removal/modification to a few systems on the truck, one of those being ABS. Now that the truck no longer has functioning ABS, a few other systems have been affected as well. I no longer have functioning Off Road Mode, Hill Decent, the Traction Control System cannot be turned off, the rear locker cannot be engaged, and 4LO will not engage. I'm assuming all these systems are tied into the ABS and not being able to use them is a byproduct of the removal of ABS.
I'm okay with not having Off Road Mode or Hill Decent, but I absolutely want my locker to engage and to be able to turn off the TCS. 4LO would be nice to have as well, but its rarely used.
I'm hoping some of you may know of some programming that can be done through ForScan or something that could help with getting these systems working again. I've done a little research and believe I can wire in a switch to get the locker working again, but not sure about traction control or 4LO.
Any advice or help that can the provided would be greatly appreciated.
-Rob
-Rob
