Next mod advice
Socalbeachbum
Huntington Beach
I would like to get an svc bolt on bumper with lights, svc bumpstops and deavers. In no particular order.
I was thinking on doing the bumpstops first then deavers, or would it just be easiest to do them at the same time?
CoronaRaptor
CANADA
Do them at the same time, depending on which bumpstop kit you go with, the bump plate bolts onto your ubolts, so why replace those twice? I think u-bolts are only one time as they stretch i've heard. Mods sound good though!!
Simplejack
dallas tx
Think there was a thread about the svc bolt on and a steering connector part or something that threw some people for a loop so I would research that one if u plan on installing your self. Just a heads up. Other than that agreed with doing both bumps and leafs at same time if possible.
Socalbeachbum
Socalbeachbum
Huntington Beach
Any recommendations on the type of bumpstops? They all seem somewhat similar (the ones on svc’s website).
Badgertits
Ma
Def do at same time, as long as you’re at a reputable shop- you’re “saving labor”
question tho- what mods have you done thus far? If you don’t have a tune yet do that first.
Socalbeachbum
Socalbeachbum
Huntington Beach
just some wheels and eibachs. I had awe 2fg (taken off) and some xl80’s which I’m selling. I’m not going to do a tune until after warranty is up. I used a tune on my old m3 and blew my motor.
BroncoAZ
Cape Cod, MA
You’re on a similar mod path to mine, although I’m not certain on doing the bumper. I’m planning to do everything at once.
Socalbeachbum
Socalbeachbum
Huntington Beach
I’ve been reading a lot about deavers clunking and rusting. They seem pretty high maintenance. I’m also looking at the icons.
Jace21583
Icons are less maintenance and you don't need to beg for an extra stuff spring like with the deavers. I'm running the eibachs up front and icon leafs in the rear on setting two with the rpg bumpstop kit, fox bumps. I don't like rpg but couldn't pass up buying the full kit from a dealer for 1k.
