New to me 2011 Raptor
rypeck1
California
What’s up guys , I joined the 1st gen crew and picked up a boarder patrol 2011 raptor with 120k miles. A few things I’m trying to figure out. So I’m almost positive my starter solenoid is out, I used a multi meter and probed the starter relay (pin 87) as well as the starter wire on the solenoid it’s self and got .4 ohms. My battery voltage was 12.6 so the math to the fuse is 31.5 amps which is blowing the 30 amp fuse. I’m assuming a new starter will fix that issue. A few other things that seem pretty straightforward but maybe someone else can prove otherwise are quite a few sensors, I have the tire pressure light on which should be simple, the srs air bag warning light, and check engine due to a catalytic converter code. I’m assuming that should be direct replacement to fix and hopefully cheap for the sensors causing the lights on the dash. When I received the truck he also mentioned the rpm gauge just recently started getting stuck at 2k rpm and still went up but wouldn’t go back below 2k even though it idled fine, I ended up hitting some dirt already and a few bumps ended up throwing every single light on my dash on and fixed the rpm gauge problem, and all the other lights ended up turning off except the ones that maintained on since purchase (Srs, check engine, airbag). I’m assuming it’s a wiring problem probably somewhere in the dash but for now it fixed it’s self lol. Another thing I want to figure out is the 4wd, my front tire driver side has a clipped vacuum line for the 4wd system, hoping it’s just a hose and not expensive. The next is cv axles and all new brakes in the next few months. Let me know if anyone has any experience with these problems and stuff to look out for as well! The truck has been semi refreshed since it’s boarder patrol days with new king 3.0s ibp coilovers and camburg upper control arms, 3.0 king triple bypass in the rear (stock location), new alternator, and a new steering rack which helps ease the mind a little. If anyone is on similar suspension i wouldn’t mind advice on some suspension tuning/ recommendation’s on a smoother ride. It’s quite hoppy in chatter, I’m assuming deaver leaf pack and some weight will help. Other then some door rattles I need to chase down it seems pretty straight forward to get it right! I have no service records unfortunately so advice on spark plugs/injectors would be greatly appreciated too. So far the truck seems to shift nice and has a healthy start up minus the starter issue I just stated to face. Thanks for the help stoked on (hopefully small) project ahead of me.
TomDirt
Hesperia CA
Did the border patrol keep service records on it that CarFax might have? Oil changes & shock service would be nice, but transmission fluid service, fuse 27, and the 6R80 software reflash to avoid the lead frame issue are all useful records to have. Did they spec a heavy duty trans cooler on these?
What about dents and dings on the frame, bumper, & skidplates? Does the gas tank skid plate have damage? Tire marks on the wheel well liner from bottoming out? Has the top front of the bed pinched the cab?
W0n70n
C Springs, CO
What made you look at the starter relay to begin with? is it actually burning fuses or just refusing to start in park? If it's not eating fuses try starting the truck in neutral, if that works fine then it is probably the infamous 6r80 lead frame dying causing the transmission range sensor to fail.
Glad to see another gen 1 get saved though, enjoy.
R
rypeck1
California
I am blowing fuses anytime it’s hot. I can start the truck cold but if I turn it off after warm and try to start it, the fuse goes. I’m gonna put a new starter in this week for the hell of it anyways but I’m pretty sure that should be it.
R
rypeck1
California
Last but not least.
When seated on the passenger side, if you look up at the headliner, do you notice 2 small evenly spaced holes that could have been made with high heels?
IYKYK
Haha shit I’ve never heard of that. I’ll check don’t think so though
R
rypeck1
California
Honestly it looks really clean. It has since gotten brand new shocks/upper control arms. No rust, I do need to find more records though thank you for letting me know what to look out for.
W0n70n
C Springs, CO
Haha sweet! Random question too, any chance you removed your sway bar?
I thought this was standard procedure?.
It depends on the suspension setup, if you get the suspension tuned with the swaybar on, I'd leave it, if you tuned without it then leave it off. It's not a major issue if you're stock and remove it but it will be noticable on highway. My Fox 3.0s were tuned with it on, so I left it attached, if I remove it she likes to sway around a lot under acceleration (Could also be a horsepower issue).
Roush2568
FRF is not for the weak
Colorado
I also have the FRS 3.0s no swaybar, suspension tuned without out and my truck is soild in every turn. I honestly can't tell any difference. I also push a few extra HPs at the tires.
101,390
60,448
Forgotten Image
