Ratpatator
Thank you for the advice much appreciated. Ill check the battery but it's only a few months old and the fuse 27 is relocated. My mechanic is suspecting the pcm failing also. Is this a common problem or not?
@Ratpatator, any updates?
Hope your issue has already been fixed but if it hasn't.....I had the exact same problem you are describing but in a 2013 ford mustang. After the vehicle was at a ford dealership for almost a month they finally decided to replace the PCM and knock on wood that finally fixed the issue. They had no explanation for why it failed and it was hard to diagnose with the infrequent limp mode and different trouble codes everytime. Hope this helps!
I've never run into this corrupt file code.
What is he using to get the info?
SCT platform is the best out there for our trucks.
As long as you have the device updated, they release updates quite often.
I just updated last month.
I really do not know this edge CTS, will it run a SCT file format?
It's important to update the SCT device.
And always return to stock before running the "update device".
The issue with loading the Tune to the truck can a low voltage condition and having things turned on or opening doors or using windows or radio.
Those things can mess up the Tuning process.
