Ratpatator
I have a 2011 with just over 95k and it has always had kind of a low idle in my opinion about 550 or so and the idle is very inconsistent always up and down sometime worse than others. It died on me at a stop light right after I bought it with about 9000 miles on it. Took it to Ford and they said everything was fine truck is within all parameters.
I have had it start to stall/ hesitate 3 different times and will start to miss on several cylinders and the wrench symbol pops up. As soon as I shut the truck all the way off it will restart and run fine with no codes no wrench symbol. If I only turn it to acc it will start but still be in limp mode. There are no codes saved on the computer from the incident. It is also still stalling on me at stop signs/lights. Does it with and without a tune on. My AFR is up in the mid 20s when it runs like ass but 14s when running normal.
Any ideas ? Bad fuel pump? plugged fuel screen hence the reset when tuned all the way off except for acc.?
