New Product Release: TMX Rear Facing Light Mounts
TEXAS MOTORWORX
Dallas, TX
Rear facing lights are required on many Raptor runs, and if they aren't required, they are highly recommended. Those of us who have been flying down a dusty road at 80mph know the piece of mind it gives you to be able to see a truck in front of you through the dust. They are also nice when backing up in the dark or at night when you have a Prius tailgating you. :emotions33:
Here is our solution...these are made of a single piece of 6061 aluminum and powdercoated black. Installation is easy...simply place in the corner of the bed, mark the holes and drill through. You will need a rivet gun and 8 3/16th long rivets (available at Home Depot or Lowes) to secure the mounts.
The mounts work with most any light...they were make specifically the TMX Blackhawk X1 or the Rigid Dually in mind. Both the TMX Blackhawk and Rigid lights come with a lifetime warranty.
TMX brackets: $50
TMX brackets and pair of white TMX Blackhawk X1: $149.95
TMX Brackets and pair of white or amber Rigid Dually: $239.95
TMX Brackets and pair of white or amber Rigid D2: $407.95
OrangeAddict
Raleigh, NC
TMX, would those still work with a BakFlip F1 cover?
Since the BakFlip F1 mounts to the rail and it looks like these mount in the corner between the rail and the back wall rail I doubt they would work with the BakFlip. That said you could just drill a hole through the BakFlip F1 cover and the mounting plate on the corners and likely be able to install the lights there.
I will go take some pics of my BakFlip install tomorrow afternoon in the day light if it helps.
DesaRaptor
Thanks guys. I will take a look at the corners as well when it gets undark.
Raptor911
Ashburn, VA
could you post a pic close-up, to see the mounting location relative to the bed? And when you do, please cut-off the light. Thank you!
