NEW Gen 3 Spyshots with Amber Light Signature
Joey Tee
New York
I guess it makes sense they’re going to use the same exact headlight as the platinum and limited, but was hoping it would be more aggressive.
It seems since the OEM on the regular F150 is basically already blacked out, the only difference is the amber color instead of white.
The reflector on the side looks cheap too, I think on our Gen 2 it’s on the inner portion of the headlight back to back with the grille, so it’s much less noticeable and more stealth.
Russ103
MD
No amber makers in the grill? Or they’re just not on?
RaptorAddict1
Greenville,SC
They will be there as they are required by law due to the width. They are most likely just not lit up in this picture. As you can see the side marker lights on the front aren’t lit up either.
Remoat
Detroit Metro
What changes are under the hood? I thought the 3.5L was going in the 2021's and the TRX answer wouldnt show up til '22 or '23. And that TRX answer is rumored to maybe have the SC'd 5.2L from the GT500 inside. I dont know but I'm curious as hell, I WILL obtain that next V8 Raptor. Thank you, I yield back my time.
