NEW Boatec Raptor Fenders and Bedsides
RaptorAddict.com
We will soon be offering the NEW Boatec fenders and bedside panels. In two weeks, Boatec will have completed these panels available with a unique difference compared to the rest. They are smooth inside and out! The front and rear have a 2" rise and a 2" bulge outward. The bedsides are designed to mount directly to the stock structure of the bed. Removing the original bedsides is required. This upgrade will give your Raptor a wider stance in the front and rear.
Fenders retail for: 300.00 each side
Bedside Panels retail for: 350.00 each side
See the difference between stock and Boatec in the images.
[/ATTACH]
RaptorAddict.com
RaptorAddict.com
Great to see some direct bolt on bedsides hitting the market!
These you actually use the panel bonding solutions. No welding and no bolting. I guess if you want to reinforce it more you can use bolts. But the correct panel bod should work. The AutoMix Panel Bond by 3M is a good one.
Aaron
Meme Corps Commandant
WA
So do the rear besides actually un-bolt from the truck or do they need to be cut off? I'm asking because if I ever went this route, being able to potentially return it to stock would be a nice option.
I'm pretty much a newb when it comes to 'glass.
RaptorAddict.com
RaptorAddict.com
This is where it's rough. It's kind of a know-how to do thing. You would have to take the bed off the truck, or find a way to slide it back and to the side enough, and then drill out all the spot welds. Use body hammers and proper tools to get everything straight after removing. Then line up the bedsides and cement them in. Once it's bonded, it's almost an undoable process to get them off without cracking, or breaking the fiberglass. Depending on what you use for bonding. If you never experience doing body panel replacement, I suggest you have a body shop do it. You'll find doing it yourself could create problems.
Aaron
WA
Ok, that's exactly what I was looking for, thanks! Definitely an involved process.
WHYUMAD
New Orleans, LA
Wow. The new fenders make it dwarf a stock raptor. I want, but idk id I'd be able to park or drive normally around here anymore.
