New Alpha 1 Spindle Gusset
Discussion in 'Outlaw Offroad' started by Outlaw Offroad, Oct 17, 2012.
  1. Outlaw Offroad
    Outlaw Offroad Supporting Vendor Supporting Vendor
    624
    306
    Apr 7, 2011
    The Alpha1 Weld on Spindle Gusset Kit.
    Just like other Alpha 1 products the new Raptor spindle gusset was designed knowing there was a need in the Raptor marketplace. The spindle gusset kit is the perfect low cost answer to preventing the OEM spindle (steering knuckle) from bending at the top mounting point. The bending is caused by the top 90 degree ear mounting point of the spindle going through full compression and the angle of the tapered pin in the factory arm causing the spindle ear to twist and bend. The bending is ever so slight at first but gradually gets worse over time causing negative camber and premature tire wear. The gusset is a full weld on kit and it is necessary for any off road enthusiast.
    • A must have reinforcement for anyone who wants to play in the dirt with your Raptor.
    • Strengthens the factory cast spindle uprights and prevents the knuckle from bending at the 90 degree top mount. This damage occurs during full compression with the factory UCA.
    • 3/16" 4130 chromoly laser cut steel brackets.
    • Welding and grinding are required to install.
    Any questions call the shop 949-581-5001
    Raptor Gussets
    [​IMG]
    [​IMG]
    Sitting on the Spindle
    [​IMG]
    Welded on RSV3
    [​IMG]
    Welded and painted
    [​IMG]
    Alpha1 Spindle Gussets
    BigScott, Donk74, MotuMute and 2 others like this.
  2. onesickpuppy
    onesickpuppy FRF Addict
    1,443
    307
    May 20, 2012
    Ruler of the Earth
    Good stuff guys!!!
  3. KaiserM715
    KaiserM715 Kaiser Söze Staff Member
    8,580
    3,082
    Aug 5, 2010
    $99 is a good price for that gusset. I might have to see if I can find someone who is good at welding CroMo to cast...
  4. treypal
    treypal Lord of the Raptors Supporting Member
    37
    4,452
    4,072
    Jun 16, 2011
    Riviera TX
    Yeah. Any info on welding that thing up?
  5. BlueSVT
    BlueSVT FRF Addict
    2,047
    1,415
    Mar 10, 2011
    San Dimas, CA
    Sweet... can't wait to have it installed next week!
  6. Lance Vincent
    Lance Vincent Full Access Member
    44
    285
    70
    Feb 8, 2011
    Knoxville,TN
    1 Can That mother just be MIG welded ???
    2 Can it be done on the truck with some wet fire blankets around soft parts?
    Looks like a nice part
    Thanks Lance
  7. Hockster
    Hockster My 45ft Bluewater Party Supporting Member
    60
    5,144
    1,854
    Aug 9, 2010
    Winchester, Va
    Ya its quite easy to weld steel to cast... steel is slightly harder than cast iron, and therefore combines fairly easily
  8. KaiserM715
    8,580
    3,082
    Aug 5, 2010
    For a MIG, do you need to use different wire?
  9. Hockster
    60
    5,144
    1,854
    Aug 9, 2010
    Winchester, Va
    Nope... Standard MIG wire works. They are really close in carbon content... Cast has a bit lower melting point...
  10. DieselD
    DieselD Full Access Member
    129
    20
    Aug 12, 2012
    Arizona
    To ensure the strongest weld you should really preheat the cast part before welding. After welding is complete slowing the cooling down is also a good idea(wrap the part in a old sleeping bag overnight for example)
Share This Page
