New 2026 Raptor 37 and a couple of questions
HookEm
Just bought a new 26 Raptor 37 and there are a couple of things I'd like your feedback on.
First is the oil pressure - it typically runs about 25 psi, but will jump up to about 65 for a while, then drop back to 25. It does not correspond to engine RPM increase/decrease every time. Is this normal for the 3.5? I also have a 23 Raptor R and oil pressure climbs and falls pretty linearly with RPM, so the 3.5 behavior is a little intriguing.
Next is the HUD. It's slightly tilted on startup. I adjust it through the dashboard by rotating a couple of clicks to the left, but it resets back to the slightly tilted position at every engine stop/start. I've tried saving it in the correct position with the R button but that's not fixing it. Is this normal?
Last thing is Apple CarPlay - when I connect with the USB-C cable, music etc. crackles and pops. When I let it connect wirelessly, it plays fine. Funny thing is when I bought it and drove it home I hadn't enabled the wireless CarPlay and used the cable for my 3 hr drive home and it worked flawlessly. Start it up the next day and it's crackling. Enabled and connected wirelessly and its all good. Now I have to get in and start the truck, wait for it to pair wirelessly, then plug in the USB so it can charge. Very annoying and I'm wondering if anyone else has had to deal with this. And yes, I've tried multiple cables with the same results.
Thanks and hope you guys can share your knowledge about any of this.
Probably Fine
Well-Known Member
Navy
Southern California
Can only speak to the HUD issue. That isn't normal. My '24 stays where I put it until I change it, or I think maybe sometimes after OTA updates (which I've now disabled since the truck is tuned).
No idea on the oil pressure, and I only use Android auto and plug my phone in on long trips but never had an issue. Funny, cable would have been the first thing I questioned so good one anticipating that.
Luckily that's what the warranty is for. I had to use mine for a couple issues when the truck was brand-new. It is what it is...
trailhopper
NoVa
Honestly none of those issues sound normal/expected to me…at least not compared to my 2025 Raptor.
My oil pressure tracks with my engine load, the hud never resets/moves, and I have never noticed any static/noise with CarPlay (granted I rarely use a cable with CarPlay and am almost always connect wirelessly).
My first thought is to charge your battery and see if that helps with the hud issue. These trucks do really weird things when the battery isn’t operating at full capacity.
fueler
Portland OR
I work at a Porsche dealer in parts, and we replace the usb ports for reasons like this. Could be that's all, loose or damaged in that area.
BrokePartsGuy
Mesa AZ
Oil pressure jump/drastic change is normal.
HUD moving.. is not normal
Cant speak for wired connections as I have never used it.
Also a Parts Manager, and yes try a different cable just to make sure (and a different phone). We had a guest with a bad port on the phone. But it could very well be a bad port like mentioned above, or even a head unit issue.
Antho
If you have a driver profile setup, try moving the HUD to the spot you want it and save your setting again. May work
H
HookEm
Appreciate all the feedback. Good to know the oil pressure fluctuation is normal. For the HUD, I'll try saving with the seat memory and see if that works. If not, I'll get it addressed along with the USB issue during the first oil change.
Ox3721
Arizona
Try a BMS reset for your audio issues. Also, check your battery. I know it’s a brand new truck, but the electronics are super sensitive to voltage and SOC. You’d be surprised how many new vehicles have weak batteries, especially Ford trucks.
101,297
60,426
wvheat
