Need some lift/tire advice
Discussion in 'Ford Raptor Suspension Discussion and Modification' started by Cristian H, Jun 28, 2020.
  1. Troy McCartney
    Troy McCartney Member
    13
    25
    Oct 2, 2019
    DFW, Texas
    Second vote for Texas Motoworx, just drive down to their shop and take a look. They won’t steer you wrong and there’s always a bunch of gen 1 & 2 raptors in there to check out.
    Smokey and Cristian H like this.
  2. Steebo
    Steebo Full Access Member
    50
    21
    Mar 8, 2020
    Colorado
    $2k is not going to be enough... thatll cover tires but that about it. I do not recommend spacers of any kind. The correct way would be to increase shock travel in the front and springs in the back. I believe a decent pair of springs are gonna be $2k right off the bat and that's before looking at bump stops. If this is purely for looks then get a spacer and bigger tires. If this is for function and form then you're gonna need 3x your budget
    TXRaptor and Cristian H like this.
  3. Smokey
    Smokey Member
    24
    35
    Aug 28, 2019
    North Texas
    Texas Motorworx is the only place I trust with my Raptor.
    there's really no reason to go anywhere else in the metroplex. do yourself a solid and go see the guys over at TMX.
    fwiw, they installed my eibach / Deaver +3's... I'm now considering bumping up to 37's
    Cristian H likes this.
  4. Jeff-Ohio
    Jeff-Ohio Full Access Member
    49
    802
    360
    Nov 3, 2016
    Cincinnati
    I am running 37" KO2's with Geiser springs up front and Deaver+3 in the rear and love the setup. The cost of the springs will be right around $2K, so you will just need to find another $700 to $1K for the spring installation and wheel alignment, in addition to, about $1400 for the tires. I would strongly suggest researching the options and doing it right the first time. If not, you will end up spending a lot more when you decide to do it right in the future due to lost labor and replacing parts.
  5. Cristian H
    Cristian H Member
    19
    4
    Jul 7, 2019
    Dallas, TX
    To get me started, could I install the Eibachs in the front and put on the 35s and just leave it at that? In other words, could I do this and then wait to do the Deavers in the back? Or is that going to just change the direction of my rake from nose down to tail down? I don't carry a load in the bed that often. Also planning on stopping by Texas Motoworx when I get a chance. Appreciate all the feedback.
  6. bruiser
    bruiser Full Access Member
    31
    90
    36
    Nov 19, 2017
    yup you can
  7. pbtjrlmrt
    pbtjrlmrt Full Access Member
    398
    259
    Feb 21, 2019
    Oregon
    There is SOOOOO much more to running 37s on a raptor than doing a lift. If your plan is for a mall crawler then fine but if intend to do off road and retain any reliability/performance then you have to spend thousands to do it right. Buy once cry once is correct but in this case a lift alone won't cut it...again...unless you are only planning it to be a street princess.
    Steebo likes this.
  8. cayenne
    cayenne Full Access Member
    482
    201
    Jul 15, 2012
    Windsor, CO
    Not no, but hell F'n no!
  9. Cristian H
    Cristian H Member
    19
    4
    Jul 7, 2019
    Dallas, TX
    I talked to the experts today at Texas Motorworx. Funny how they can convince you to exceed your budget by knowing their shit. Gonna go with the Eibachs, Deaver+3, bump stop, and Toyo R/T 35s.
    Sent from my SM-G973U using Tapatalk
    Jonny V, Smokey and Maintecheib like this.
  10. BroncoAZ
    BroncoAZ Full Access Member
    406
    208
    Sep 27, 2019
    Flagstaff, AZ
    Sounds like a good setup.
Share This Page
