Need Mudflaps BIGTIME
Discussion in 'Ford F-150 Raptor General Discussions [GEN 2]' started by dizzydog, Jan 11, 2018.
  1. dizzydog
    dizzydog Member
    37
    Dec 28, 2017
    Chandler, AZ
    Rained here in Phoenix for the first time since I had my truck.
    Drove around a bit and holy cow do those front tires (35" KO2's on 18") throw up some major mud and dirt all over my front doors!
    I need an easy to install mudflap that won't require drilling.
    What do you guys recommend?
  2. k-rub
    k-rub Full Access Member
    434
    184
    Oct 3, 2016
    Tucson, AZ
    Weathertech flaps work great for me.
  3. naamanf
    naamanf Full Access Member
    43
    62
    35
    Apr 28, 2017
  4. downforce137
    downforce137 Full Access Member
    585
    294
    Jan 5, 2016
    In Diana
    PDP flaps.
  5. Smokeshow60
    Smokeshow60 SgtMajor of the MemeCorps Supporting Member
    695
    380
    Sep 21, 2017
    Southern Ohio
    I recommend using the search function. In the dozens of mudflap related threads I'm sure you'll find the information you seek.
    dude1782 and squeak like this.
  6. dizzydog
    dizzydog Member
    37
    Dec 28, 2017
    Chandler, AZ
    Ive emailed those guys 2x asking about install process and haven't heard back. Do they require drilling??
  7. Smokeshow60
    695
    380
    Sep 21, 2017
    Southern Ohio
    No. Very easy and clean install using factory screws and holes. U just need to put the holes in the flaps themselves
  8. rtmozingo
    rtmozingo Full Access Member
    26
    417
    115
    Aug 3, 2017
    North Texas
    PDP is the cleanest look, and has held up to 400 miles of offroad abuse, including full suspension cycling. Uses factory screws, and you can get the Raptor logo on them in any color. Hit up Chris Kelly of Freedom Motorsports for a set. They run fairly cheap too.
    smurfslayer likes this.
  9. smurfslayer
    smurfslayer Be vewwy, vewwy quiet. We’re hunting sasquatch77
    3,426
    2,026
    One of the Gen 1 guys posted a how to that’s insightful. You just need to make a template from the truck, measure where you want your flats - for once, you get to control the horizontal and the vertical :biggrin: mark the template, match up the template with the mud flap, re-check and drill.
    mount the mud flap. Repeat as needed.
    I got a set of 4 PDPs, but I only run them in the front. Whatever clean up / damage I might mitigate with rear flaps is not worth it to me so that I can throw an epic, tractor trailer like wake in the rain.
    :biggrin::biggrin::biggrin:
    rtmozingo likes this.
  10. Smokeshow60
    695
    380
    Sep 21, 2017
    Southern Ohio
    I just held the flaps up in place on the truck where I wanted them and firmly pressed them against the existing bolt heads. The PDP flaps were soft enough that this left a slight impression on them where I then simply drilled the holes. Worked perfectly. Took less than 15 minutes to install all 4
Share This Page
