Need help please grinding noise
1BAD454SSv2
HELL I ZONA
Un plug vacuum line from solenoid , put cap on solenoid port so you don't have a vac leak. Drive it, if noise is still there , you may have a hub bearing issue or bad Cv joint. If you don't have noise you have a leak in your lines or check valve it is partially engaging hubs when engine vacuum varies under driving conditions.
CarlosnVegas
Las Vegas, NV
Hello Tony. Vacuum line went to the IWE. Front wheel. My local mechanic tied in the old smoke machine after the vacuum check valve located along driver firewall. He may be able to explain better. His name is Will 702-463-0974. Mention Carlos w/ the Raptor.
vegascarnut
Henderson, NV
Those lines are going to keep breaking and cracking. If you plan to keep them, upgrade to silicone.
tonyraptor
tonyraptor
You can have good hoses, good solenoid, good check valve, and even maintain a vacuum at idle, but if one of your IWE diaphrams has a small leak, it will bleed off enough vacuum under a load to start grinding. This just happened to me. Do a vacuum test on each IWE. Just disconnect the line, put the vacuum gun on the large port, and pump it up. If it holds, it's good.
P.S. You didn't mention whether or not you replaced the $13 check valve. Those fail all the time. View attachment 152131
Hi , I did replaced the ck valve
tonyraptor
tonyraptor
Here is a video of the grinding noise , is not a constant noise if you drive “normal” is fine the noise only happens on acceleration like when you are going to pass someone
Maybe someone has had the same problem thanks
badm0t0rfinger
Rocket Man
The Beach
That sounds like something transmission related for sure. It could also be a transfer case issue; when mine went out a few days prior it was making some oddball noises. It failed in 2Hi so I was able to drive it around until the new one arrived at the dealership.
vegascarnut
Henderson, NV
Tony, the best check for this is to unplug the vac line at the solenoid—the one that goes to IWEs. Cap it at the solenoid. If it still makes the sound, in my opinion it sounds like a loose heat shield vibration.
tonyraptor
tonyraptor
I already did that , that video was taken with the hose loose and the selenoid cap will recheck all heat shields thanks
