Help SupportFord Raptor Forum by donating:
Help support Ford Raptor Forum :
Narrowband Air/Fuel Ratio Gauge
Discussion in 'Ford F-150 Raptor General Discussions [GEN 2]' started by angusmcraptor, Jun 18, 2019.
  1. angusmcraptor
    angusmcraptor Member
    25
    3
    Sep 8, 2018
    Miami, FL
    Looking for advice in installing a Narrowband Air/Fuel ratio gauge in a Gen2. Need to know stuff like where is the Air/Fuel Ratio Oxygen sensor etc...? Starting from ground zero here.
  2. SilverBolt
    SilverBolt Hired Gun
    2,466
    981
    Jan 12, 2011
    Portland, OR
    Narrow band? Most use wide band to monitor A/F ratios.
  3. angusmcraptor
    25
    3
    Sep 8, 2018
    Miami, FL
    Was looking into that. Not sure if ability to modify the mix would void the warranty. But I'm considering it too.
  4. Turbo95max
    Turbo95max Full Access Member
    39
    151
    27
    Jul 20, 2012
    San Bruno, South SF, Petaluma
    A narrowband A/F ratio gauge is only good for a light show. Is this for looks or for tuning purposes? No real aka reputable tuner ever uses a narrowband O2 sensor for tuning. The 02 sensors will be located before the cats and after the cats. The ones that are used for tuning/engine control are the primary ones. Sometimes called upstream O2s. The ones before the cat.
  5. Sernas
    Sernas Member
    28
    39
    13
    Jun 18, 2017
    Gen 1 Raptor has stock o2 sensors that are wideband from the factory. I would imagine the gen 2 to have them as well. All you need is a monitor like a scan gauge that plugs in to your obd port. Pick afr left and right bank out of all the parameters. I used my SCT X4 to monitor my afr when my truck was boosted.
    Blusmbl likes this.
  6. angusmcraptor
    25
    3
    Sep 8, 2018
    Miami, FL
    OK... I'm talked into wide band. Sounds like climbing under the truck instead of digging around under the hood. Looking for a 52mm gauge. Any suggestions?
  7. brianh87
    brianh87 Member
    47
    13
    Mar 3, 2019
    Pittsburgh, PA
    I responded to this on the other forum too. We have wideband O2 sensors stock. There is also a readout on the dash that you can monitor for AFR's. If you wanted a separate gauge, it would probably be easy. Just be careful because the that sensor is extremely important.
  8. angusmcraptor
    25
    3
    Sep 8, 2018
    Miami, FL
    Thanks again. Now I’m rethinking. Might just need to invest in a good tune.
  9. MEATSWORD
    MEATSWORD Full Access Member
    181
    69
    Mar 23, 2019
    Arizona
  10. KYmxracer52
    KYmxracer52 Full Access Member
    138
    40
    Nov 1, 2013
    Central KY
    The Aeroforce Interceptor gauge will read the A/F ratio and plugs into the OBD II port.
Share This Page
