Name this random hose:)
Gr8-19SC
Ca
Hello all, wondering if anyone knows where this hose is supposed to be?. After some raptoring I noticed it hanging on the driver side about half up the transmission riding directly on the front driveshaft. What yall got?
Thank you.
CoronaRaptor
CANADA
Wondering if that is the front dif vent hose that is suppose have a white breather fitting on the top, it is usually mounted to the drivers side of the master cylinder. See if it's still there or not.
Marlboroman
Colorado
The entire assembly is available from the dealer for around 60 bucks. It hooks up to brake booster on the above mentioned clip. It’s a multi hose line about 3 feet long.Should be a diagram out there. Front differential vent line.
