the 4R60 transmission.
as well as not occupy much real estate under the hood.
The integrated 9" SPAL Fan provides ample airflow and also pushes air into the factory radiator
"NOT TO THE BUMPER" bumper mounted coolers will fail with any skid plate ot bumper impact.
Core mounted behind grill. NOT BUMPER. Front impact safe.
And our input on the above information....
1- The Raptor has a 6r80 not a 4r60
2- Take a look at the picture below, it does impact air flow getting to the radiator. Recently we had fabricated a new bumper for a customer and we had moved his trans cooler up a bit from where it normally is between the frame horns. We had 50% of the trans cooler in front of the lower section of the radiator. Looking at it we did not think it would effect air flow and cause any heating issues. To our surprise it did increase his engine temps by 10-15 degrees when he was offroading. This didn't cause his motor to over heat just to run warmer than normal. We remounted the cooler and his temps are back to normal. If our 50% of a cooler caused that type of change in temps...
3- The air you are "pushing" into the radiator has gone through the transmission cooler. If your tranny temps are going to be in the 170-220 range the air that you are "pushing" into the radiator is going to be how hot? Also adding just a fan to the front of the radiator can block air flow and hurt your cooling rather than help it. You are adding not only a fan but a cooler and a shroud.
4- Our mount is designed to fit between the frame horn and is protected by the bumper. If you are running our winch mount we have a different lower mount for you that is protected by our skid plate. The cooler does not mount on the skid plate but is rather protected by the skid plate.
SDHQ behind the bumper mount-
SDHQ lower mount-
5- If a person is going to get into an accident that causes the bumper to crush our cooler you will also be vulnerable with a cooler behind the grille. Also see my #4 post
And the long travel issue-
From their post - "and feature one inch Uniballs and 4130 machined spacers for all the pivot points. No sloppy bushings here!
Their selling point is we we use bushings and they use uniballs... We actually use delrin in the lower arms not a poly bushing. We chose to use delrin for a couple reasons.. Delrin is actually much harder than the poly bushing it was claimed we were using... It will also out last the uniball in the frame side lower arm... We designed our lower arms with exact tolerances... We do not need the additional misalignment that is given when using a uniball to align the lower arms... No sloppy bushings here...
