Mishimoto Transmission Thermal Bypass
screaminfast
Rochester NY
Has anyone installed one of the Mishimoto Transmission Thermal bypasses? (Link) I am putting in a new cooler block there because mine is very gross and I am making some new -8AN lines to go to the Full-Race / CSF cooler, but I was wondering if I should grab one of these as well. Thoughts? I am trying to figure out if I need the seal kit and new bolts as well. I think if I don't get the Mishimoto, I will definitely need the seals.
Meat2022
Army Supporting Member
Alabama
Yup I have the full flow version and keeps my transmission in the 160s to 180s. It’s been on for almost a year now I believe and zero issues.
Did it help with the ****** shifting issues any ?
andresamador
Miami, Fl
Nope. ****** shifting went away after a full rebuild and goosetune. I purchased a third party aftermarket warranty and had zero issues getting it covered, didn’t pay a dime.
screaminfast
screaminfast
Rochester NY
Good to know. Did you need to order any other seals or anything from ford for the lines? I will probably end up getting the one with the t-stat since I live in NY then I can pull it when I eventually move to FL
I bought a new heat exchanger off eBay so I’m going to cerakote it.
andresamador
Miami, Fl
I had the transmission shop that install it replace all the all seals while it was taken apart. I’m very big on replacing gaskets even reusable ones with new ones while anything is apart.
Was it necessary? I’m not sure.
andresamador
Miami, Fl
Bypass still working out well?
I ended up removing and going back to stock. The transmission did not like being that cold. My engine thermostat is 170 degrees and replaced my transmission heat exchanger with a new oem unit keeps the temps between 180 to 195 degrees. The shifts are a lot smoother.
thatJeepguy
GA
Great mod, especially if towing or hard use. If your trans temp regularly climbs into 212+220f you’d better be changing that fluid every 40k miles.
thatJeepguy
GA
Are you sure your trans had the correct fluid level?
andresamador
Miami, Fl
That was the first thing we verified. I read somewhere where that the fluid was designed to run above 180 degrees and above that temp is when it’s at the correct viscosity for the transmission.
I wanted to see if this was true because the rebuilt transmission was installed with the thermal bypass.
I bought a new oem heat exchanger and the first day I could immediately tell the shifts were smoother and just felt better overall.
welndmn
Concord
I have the full flow, but I live in CA.
I swapped it on a trip in Baja it stuck and overheated my transmission.
I tow, I off road, it's been fine, but it also does not get cold here.
andresamador
Miami, Fl
I live in south Florida but I don’t tow. I drive with a purpose lol. I was seeing 160 degrees in Joe La day to day traffic and 170 max when pushing it.
Now it sits at 180 degrees and max I see is 195. 20 degrees made such big difference for my transmission at least.
thatJeepguy
GA
Fun fact ULV fluid is able to maintain its viscosity because it has zero addition of polymer viscosity improvers. The base oils are blended with antioxidants and detergents . This makes it sheer proof.
22R37
staten island NY
I have installed the Mishimoto Transmission Thermal bypass with the thermostat. Planed to install also a Mishimoto transmission cooler but never did because my temperature never vent over 180 even when towing over Rocky Mountains. My kit came with all the hardware needed, no additional parts required, but I have a Gen 3 Raptor.
screaminfast
screaminfast
Rochester NY
I ended up buying one. Working on making the custom fittings and lines. I had all the required parts already but I’m doing it my way.
101,284
60,415
Gerth
