UPDATE; Mildew smell in the cabin after it rains.
BangBang
My 2018 just within the last month has started having a mildew smell in the cabin after it rains.
There is zero wet carpeting. Just the smell. I cahnged out the cabin air filter, but that didn't help.
I did a search, but all I could find are posts where peoplr had wet carpet in thre cabin.
Any help would be a preciated.
One person as said the cabin vent, the one for when you shut doors to equalize the pressure on his ford F150 had become dislodged and leaking. I can't find that vent. He also said he had wet carpeting. He and I searched my truck today for any wet carpet and the was none. We had rain last night.
JohnyPython
Canada
Cabin vents are behind the rear seats. Usually the culprit. If you have a sunroof check that too.
BangBang
BangBang
No sunroof.
I will drop the back seat tomorrow and check.
What is the fix? Replacing them?
JohnyPython
Canada
No sunroof.
Since I’m reluctant to go to the dealer, and because of the virus, I would remove the vents, clean them with bleach and reinstall. I believe that they are installed from the outside of the cab. I read that someone was able to install them from the inside without removing the bed.
BangBang
BangBang
Thank you. Yeah, I hear ya. When changing out the cabin air filter I strong armed the actuator arm. Loaded some stuff in the bed and the right tailgate bumper attachment screw broke. Ordered them both from Tasca yesterday so I won't have to go to the dealer.
TScozz
Aubrey, TX
Check the door plugs too. No issues on my Gen 2, but on my Gen 1 I had this issue. My drain hole on the passenger side was plugged. I unplugged it, and some nasty smelling water drained out. Left the door open and smell went away.
Sent from my SM-F900U using Tapatalk
Derail
When you check the carpet, are you checking under the carpet? It can be wet under it and not show on top.
BangBang
BangBang
Thank you
