Mid-Mount Turbo
Discussion in 'Ford Raptor Engine Discussion and Performance Mods' started by Topgunz, Jul 1, 2018.
Sponsored By: GotExhaust
  1. Topgunz
    Topgunz Member
    47
    15
    Jul 26, 2016
    The comp turbos had their issues when they first came out. Now they have dialed them in to be very reliable. The order has already been placed and paid for. The turbo should be here in about 2 weeks.
  2. Topgunz
    Topgunz Member
    47
    15
    Jul 26, 2016
    What are you fi guys running for plugs/gap. Been reading anything not OEM may cause problems. My tuner said gap to .035 but that is way under factory lower limit of .041. Any advice?
  3. DWH3
    DWH3 FRF Supporting Member Supporting Member
    15
    6
    Jul 6, 2016
    Dallas, NC
    JDM recommended .030 for my Roush with NGK Iridium Spark Plugs
  4. Topgunz
    Topgunz Member
    47
    15
    Jul 26, 2016
    Does anyone know where to find a 3.5" Ball flange for this truck?? This is my only hang up as it seems like most guys report they have a 3" collector for the ball/mouth flange. Basically, I need the ball flange that mates to the Y-pipe where the downpipes/cats collect where the stock resonator would go. Even if I look to buy a stock resonator it comes with a 3" flange. I doubt the guy before me put on aftermarket downpipes/cats since they look stock. They measure 3.5" though. :confused:
  5. Darthyota
    Darthyota Full Access Member
    595
    93
    Jan 28, 2014
    Alberta Canada
    Why not use a v-band instead of the ball mount?
  6. Topgunz
    Topgunz Member
    47
    15
    Jul 26, 2016
    Because I dont want to have to cut the factory Y pipes flanges off for a few reasons.
    1. While I am fabricating this I still need to use my truck and need to swap the current exhaust on and off.
    2. If I ever sell the truck I will pull the turbo off and place the stock exhaust back on.
    3. If I ever duplicate the kit I do not want to make someone cut anything and/or modify anything stock that they can not put back on.
    I have finally figured it out though and am having a shop custom make me a 3.5" ball flange.
    I will be using a V-band from the reducer to the T4 exhaust inlet flange. Also on the turbine out to mate to the exhaust.
    As of right now I have everything on order except the intercooler and water line fittings since I do not have the turbo. That should be showing up by the 23rd and then fit up begins.
    FarFromStock likes this.
  7. Topgunz
    Topgunz Member
    47
    15
    Jul 26, 2016
    Parts are rolling in...
    Idleone and Booth9999 like this.
  8. cwylie
    cwylie Full Access Member
    35
    155
    27
    Jul 2, 2018
    Yeah mid mount on a truck is a bad idea. Plenty of room to mount them else where.
  9. Topgunz
    Topgunz Member
    47
    15
    Jul 26, 2016
    There are thousands of them out there. I'll love it.
    Can you please elaborate on why you think it's so bad? And please don't say because you swamp up above your running boards in mud all the time or drive it over Mt.everest because while that is the capability of the truck...95% of guys don't do that.
    These trucks cost too much for most guys to take the chance of leaving a scar. Or they are city trucks, or they just don't do that sort of thing and love the truck anyway. They can do more than mud/climb and have the performance and look good while doing it.
    Personally I use mine to get to work, haul my quad to the trails and to tow my camper. Just like the other 2 raptor owners that work there.
  10. Topgunz
    Topgunz Member
    47
    15
    Jul 26, 2016
    Are the stock 02 (wideband) sensors good enough to measure AFR's when tuning? Are a lot of you boosted guys running a standalone AFR gauge and sensor?
Share This Page
