MH1 Light Build
Discussion in 'Raptor Retrofit' started by c-ne-elk, Sep 18, 2012.
  1. c-ne-elk
    c-ne-elk Full Access Member
    228
    83
    Mar 9, 2012
    El Paso, Tx
    Kudo's to Dawson at Raptor Retrofit! Excellent product and he even made sure I could get my lights in time to install before I take off on a 1.5 week trip! I never expected that when I ordered them but once Dawson found out I was leaving he jumped on them and got them to me. WHAT A DIFFERENCE these lights make! Not only do they look great, but they also light up the night!
    Dawson aka Ducati, U DA MAN!!!!
    Here is my build:
    MH1
    Reflector Blacked out
    Turn Signal Blacked out
    Side amber reflector tinted
    Gatling Gun Shroud painted Ingot Silver
    LED Rings - outer
    5000k bulb temp
    It took me less than 2 hours to install and adjust the lights, super easy. If you do an install about all you need is a 10mm socket to remove and replace the 3 bolts that hold the lights in. Will also need a self tapping screw to mount the relay to the sub frame, can use exisiting holes to mount the ballast with the bolt and nut that is provided. Be sure to wire brush/sand the paint off the frame at the rear of the ballast to get a good contact for your ground. Just watch Dawson's video, it really is as easy as it looks.
    Here is what they look like:
    Blind1, Squatting Dog and Bluoval1118 like this.
  2. Raptor Retrofit
    Raptor Retrofit HID Specialist Supporting Vendor Supporting Member
    44
    1,970
    1,173
    Jul 22, 2010
    NY
    Glad it worked out for you buddy. Thank you for sharing the info and pics.
  3. Macman
    Macman FRF Addict
    31
    2,195
    642
    Jan 1, 2012
    Halifax, NS
    Those look awesome!
  4. NickPic83
    NickPic83 FRF Addict
    37
    9,641
    2,434
    Jan 31, 2012
    Rockland County NY
    They look great. Nice work by Ducati as usual. Could me do me a favor and take a straight on pic like the one in ur post but in good lighting(during day or under bright lights) Plz. Thanks
    Sent from my DROID RAZR using Tapatalk 2
  5. c-ne-elk
    228
    83
    Mar 9, 2012
    El Paso, Tx
    Here you go NickPic, one light in bright sunlight one light in partial shade. Photo's from my Bberry do not do them justice.
    Raptor Retrofit likes this.
  6. NickPic83
    37
    9,641
    2,434
    Jan 31, 2012
    Rockland County NY
    Perfect thank u!
Share This Page
