MBRP Black Series 3" Stainless Steel Cat-Back Exhaust System with 5" Tips for 2017-2018 F-150 Raptors.
If you want your new 2017-2018 F-150 Raptor to roar down the street wherever you go, than you'll definitely need to upgrade to this MBRP Black Series 3" Stainless Steel Cat-Back Exhaust System with 5" Tips (S5263BLK), available to purchase here at CJ Pony Parts!
MBRP Cat-Back Exhaust Features:
- High-quality mandrel-bent 3" stainless steel tubing
- Crafted from 409 stainless steel (to midpipe) and 304 black-coated stainless steel (tailpipes and tips)
- Direct-fit upgrade system reuses OE factory mounting points
- Loud, aggressive race-inspired sound
- Includes two (2) 5" black coated adjustable twin tips
- Up to 9 HP @ 8 ft./lbs. power increase
This complete upgraded exhaust system from MBRP will give your new Raptor the aggressive sound it so desperately needs! Your Ford truck's stock cat-back system leaves you wanting more, and that's exactly what this direct-fit system will give you. This new cat-back features 409 stainless steel to the mid-pipe and black coated 304 stainless steel for the mandrel-bent tailpipes and tips. It also includes two (2) huge 5" adjustable twin tips, so everyone can see exactly where that sound is coming from. What are you waiting for? Pick up your new exhaust system from CJ's today!
Exhaust System Specs:
Exit Type: Dual Rear
Connection: Cat-Back
Main Tubing Diameter: 3"
Comes with Tip: Yes, Pair of 5" Single Wall Tips
Bolt-On Install: Yes
Sound Level: Race
Power Increase Numbers: 9 HP, 8 ft. lbs.
Construction: 304 and 409 Stainless Steel
*This cat-back exhaust system features both 409 and 304 stainless steel. If you prefer full 304 stainless steel construction, please see S5263304 instead.
Typically performance and sound are two key factors in putting an exhaust on your F-150. While many brands offer one or the other, MBRP offers both in their extensive selection of full exhaust systems and exhaust parts. CJ Pony Parts offers many parts from MBRP at a variety of different prices, levels of performance and sounds, so you should be able to find the best for your individual needs.
Order this upgraded MBRP (S5263BLK) Black Series 3" Stainless Steel Cat-Back Exhaust System with 5" Tips for your new 2017-2018 F-150 Raptor today from CJ Pony Parts!
Sound Level: Race
