Maybe exhaust leak?
radelow
I have a 2013 Raptor. Recently a ticking has started on the right side of the engine. Starts out loud when the motor is cold but then goes away as the engine heats up. Even when warm I can hear the ticking under acceleration coming from the right side. Almost positive it is an exhaust leak somewhere. Any common areas leaks originate from? How hard is it to replace the exhaust manifold gaskets?
Thanks!
FYI it has a Whipple on it so guess it was only a matter of time.
Nex
RIP CoronaRaptor
Washington State
Hard to help you fix your issue with only words on a screen. Try uploading a video. Also check under the truck. Any loose clamps, broken manifold bolts or holes in the exhaust system?
mpk1996
If it is an exhaust leak. I’d be looking at the manifold for a crack. That has happened to guys before
