Help SupportFord Raptor Forum by donating:
Help support Ford Raptor Forum :
Maxxis Razr MT 35/13.50/17 on stock beadlocks
Discussion in 'Ford Raptor Exterior Forum [GEN 2]' started by wweaver, Feb 14, 2018.
  1. wweaver
    wweaver Full Access Member
    60
    29
    Aug 17, 2016
    East TN
    Looking at upgrading the tires on my 2018 with the stock beadlock wheels. Truck is getting the RPG 1.5 collar in the next couple weeks. Maxxis Razr MT 35 13.50 17 tires spec at 14.2 in wide but are approved for a 8.5 in wide rim. Height wise they should fine at 34.8 inches but does anyone think the width will be an issue ?
  2. butts182
    butts182 Full Access Member
    86
    32
    Jan 14, 2017
    Jupiter, FL
    I’m thinking they won’t be much of an issue on the factory wheels but would like to see how you end up
    ---------- Post added at 01:42 AM ---------- Previous post was at 01:40 AM ----------
    I am also wondering if 37” KOs will fit on factory wheels with the 1.5” collar. I have the 1.5” collar (ICON) and have more than 2” of clearance from the fender liner. KO 37s are only 2” bigger in diameter than factory so thinking they might actually fit without rubbing.
  3. Ecoop
    Ecoop Full Access Member
    131
    64
    Feb 7, 2017
    Why not go with the LT315/70R17 still get your 35" height and 13" wide and load range D which will give you a little more flex in the sidewall than the E range one.
  4. wweaver
    60
    29
    Aug 17, 2016
    East TN
    Most of the 315/70/17 Are 34.4 or 34.5 and 12.6-12.8 width. Just looking to go with a more aggressive tire and something different than the stock ko2. 14.2 wide is two inches wider than the stock C range ko2 on there now which are 12.4 wide. I have a buddy that has the Razr MT on his JK Jeep and he loves them.
  5. Loufish
    Loufish Full Access Member
    60
    614
    296
    Dec 30, 2017
    Burbank CA
    I've always run narrow wheels, it pulls in the sidewall to help protect them...that's in desert running, for mall prerunning I have no idea.
    P.S. NOT saying the OP is mall running, just used the statement as an example... :)
  6. wweaver
    60
    29
    Aug 17, 2016
    East TN
    No iam not into mall running, however a Starbucks once a week or so..... the truck is 50 percent DD and spends about a month out of the year on hunting trips in the Rockies in some pretty bad areas at times.
    After looking at the A arm clearance I am not going to be able to pull it off without doing a spacer, not sure if the 1/4 inch would be enough or it’s move to the 1.5 inch and iam not wanting to do that. Looks like a true 13.25 maybe 13.5 inch width 35 inch tire is about all you can do on the stock wheel. The 14.2 in width is not going to cut it.
  7. wweaver
    60
    29
    Aug 17, 2016
    East TN
    Bump. Has anyone tried these yet?
  8. rtmozingo
    rtmozingo Full Access Member
    27
    785
    312
    Aug 3, 2017
    North Texas
    No, but I'm interested to see feedback. Also, do you think the 1.5 collar is necessary to fit them height-wise?
  9. wweaver
    60
    29
    Aug 17, 2016
    East TN
    Probably but have done the 1.5 collars already when I did the +3 deavers and bump stop kit a few weeks ago. I may see if a local shop that is a Maxxis dealer will test fit these for me.
  10. Shahab Jeddi
    Shahab Jeddi Member
    26
    5
    Jan 7, 2019
    Arizona
    Sorry to bump an old thread, but anyone end up doing this setup?
    35x13.5r17 Maxxis Razr MT...
Share This Page
