making these old shocks look new again
FN-2187
Bay area, CA
the set of 3.0s i've got on the raptor now are looking really rough. the bodies are in need of some serious loving, the internals could use better valving and a full rebuild. a few years of living by the ocean has taken its toll on this poor thing.
What are my options for re-coating? I've heard the new thing with shock bodies are cerakoting them for a more durable finish. anybody have experience with cerakoting theirs? as they sit currently, they are badly rusted and I assume they will need to be totally stripped of their zinc before either re-plating or cerakoting. (see pics)
the springs will need to be powder coated when its all disassembled.
they also are a very stiff ride. I'd like to get them re-valved to get better performance off road. as it sits, bumps are more "jaring" and it doesnt seem like the suspension really works as it should. ive ridden in other raptors with Icon 3.0s and its a much different/softer ride.
suggestions on what I should do?
is there a solution for protecting the rear shocks from flying debris being kicked up by the front tires?
Jhollowell
Everett, wa
This is funny. I was just about to do a write up on the same thing. I’m in the process of refinishing some stock 2.5s now. I used some chemical paint stripper to remove the clear coat. Then used a scotch brite combi-s wheel and drill to polish them. Then i sprayed them with cerakote clear. I’m planning to replace the decals and then cover the whole body with clear 3m motorcycle number plate background vinyl
Paint stripper
Polishing wheel
F
FN-2187
Bay area, CA
Paint stripper
Polishing wheel
good idea to wrap them after spraying. It would certainly help protect them from rock chips and debris.
those look great. how hard was it to cerakote?
Jhollowell
Everett, wa
I’m going to try to get the decals and vinyl on tonight. Will post up when they’re done. I still need to spray the perch retaining rings and the upper part of the front shocks.
---------- Post added at 08:04 PM ---------- Previous post was at 07:59 PM ----------
Cerakoting is pretty easy if you have all the stuff. I set up a make shift spray booth with some old bed sheets in the garage. Hang them from some webbing and spray. The key is to get them clean. So polish them then wipe with acetone before spraying. It goes on really thin so i only taped up the shaft I would have preferred to powder coat them clear but i would have had to take them apart and didn’t want to tackle that. I think cerakote and vinyl should be sufficient and if not I’ll just refinish them again.
Jhollowell
Everett, wa
I just cleaned the blue parts with acetone and a scrubby sponge. Then clear coat with cerakote. They ended up a lot more shiny than i was expecting. I really like it. My girlfriend has a vinyl cutter and makes decals so i just had her make a few for me. You can buy the oem ones from sdhq
Here’s a pic of the decals. I still need to add the clear viny
downforce137
In Diana
hows the PC holding up to off road/regular use?
the powder is looking great, but I also just put them on in January and only did Snoball(1300mi round trip) and about another 3000 road miles. I keep them cleaned up and I've been spraying the heim ends with silicone. Haven't noticed any rock chips, powder is pretty resilient. I didn't coat the fronts due to the threaded perch, but looking back I should have called king and asked about it. I bet the perch would have clamped down just fine..
BenBB
Lots of different places
How much time did you spend dialing in the compression and rebound? Icons will ride differently as the valving is designed to be softer the harder the hits get, and firmer on smaller stuff, where your Fox should soak up little hits smoother, largely dependent on how the bypasses (and bumps) are adjusted (sorry if this is redundant or anything, trying to learn myself). Ideally the rear compression damping would be a smooth transition over to the bump stops as they travel through the compression stroke and the bump stops absorb that final hit. IMHO time spent adjusting, testing, and documenting everything is time well spent. And doing it all over again for different conditions...
Aside from other's suggestions you could also look at some mid flaps and/or Rokblokz. Hard to tell what's doing more damage, moisture or impact, but were they mine I'd be washing them often and considering some Amsoil HDMP or something. Rust is evil.
That is bad ass, they look damn near new. WELL DONE!!!!
